Passenger side drive axle and intermediate shaft - Kia Forum
post #1 of 2 (permalink) Old 07-10-2019, 02:31 PM Thread Starter
Drives: 2008 Rio5, 2012 Sorento 2WD, Goldwing, Ural, Chinese scooter, recumbent bicycle, two feet
2012 Sorento, 104,000 miles. Little bit of a rumble at low speed on smooth pavement, it matches wheel rotation speed and I don't suspect wheel bearings. The passenger side inboard boot is leaking grease, just gonna replace both drive axles. It 'looks' like I can just yank the drive axle on the passenger side from the intermediate shaft. I have both axles on hand but not the intermediate shaft.
Couple questions -
Can I indeed just pull the passenger side drive axle from the intermediate shaft?
Am I being penny wise and pound foolish? Should I just spring for the intermediate shaft and replace it also? Makes sense to do it while I'm there but not if it's a pretty much non-failure item.
emag is offline
post #2 of 2 (permalink) Old 07-11-2019, 02:33 PM
Drives: Sorento 2012
Quoted: 21 Post(s)
I don't know if this will help you but you can page through it and see: Kia Sorento: Front Driveshaft Components - Driveshaft Assembly - Driveshaft and axle - Kia Sorento XM 2011-2019 Service Manual
At the bottom of page, click on "Front Driveshaft Removal and Installation" and then you can keep paging through.
I believe that the inner shaft bearing bracket (#2 in first drawing) for the V-6 is only available from KIA, so be careful when praying or pulling around this bracket. If it gets damaged, it can get expensive. As for the boots, I spray silicone on my boots when I change my motor oil. This seems to lube and protect the rubber boots as I have not had one break on me since I started spraying them on my cars years ago.
jolt2 is offline
