Replaced Oil Pressure Sending Unit, now I have a P200A check engine code. - Kia Forum
 1Likes
  • 1 Post By jolt2
post #1 of 6 (permalink) Old 07-01-2019, 02:13 PM Thread Starter
Drives: 2013 Kia Sorento EX 3.5L V6
Hi guys, I replaced my oil pressure sending unit and when I put everything back together, part of the intake manifold was propped up slightly, creating a huge vacuum leak. Surprisingly, even though the intake manifold wasn't mounted completely flush, all the bolts went on perfectly fine, and it looked to be mounted flush from the front of the engine. Apparently it was propped up in the back.
As you can imaging, this caused a number of issues and check engine lights. Once I re-seated the intake manifold, all of the check engine lights went off and the car is now running great. However, I still have the P200A Check Engine code, even after a few hundred miles of driving and clearing the code a few times.
Knowing that I had both the upper and lower intake manifolds off, and that I misaligned the upper intake manifold on my initial reinstall, does anyone have any idea what this could be? Prior to replacing the oil pressure sending unit, the car ran great. Even now, the car runs incredible, no loss in power, perfect idle, great fuel economy, etc. Outside of having the P200A code, you'd have no idea there was anything wrong.
I should also mention that, when I clear the code using an OBD2 reader, I hear the PCM click and it appears to be functioning properly. Then the check engine light will stay off for at least a few miles of driving before it kicks back on. Also, since I have the OBD2 reader, I can see real time AFRs, fuel trims, throttle position, etc. so if there is a specific parameter I should check to help diagnose this issue, definitely let me know
I found an article on obd-codes.com (can't post the link, I'm too new of a member). I just need to find time to go through all the diagnosing steps. But if anyone has a suggestion of what to check first, given the circumstances, I'm all ears.
Thanks in advance for any help!
Eric Arroyo is offline
post #2 of 6 (permalink) Old 07-01-2019, 02:30 PM Thread Starter
I should also clarify that I have a 2013 Sorento EX with the V6.
post #3 of 6 (permalink) Old 07-02-2019, 10:21 AM
Drives: Sorento SX FWD 2015
Quoted: 25 Post(s)
Did you hook up the VCM linkage, or maybe mess up the vane in the manifold. Doubt you have a GDS, but you can get the idea of how it should work here. https://kia.oemdtc.com/254/vcma-diag...13-kia-sorento
I'm Bob, 2015 Sorento SX , 2007 GMC Envoy (tuned) , 1994 Camaro Z28 (modified/custom tuned)
bobdec is online now
post #4 of 6 (permalink) Old 07-04-2019, 03:19 PM
Drives: Sorento 2012
Quoted: 21 Post(s)
You can watch these video's to get an idea of what it is and how to troubleshoot the problem.
Watch both videos.
mayers_929 likes this.
jolt2 is offline
post #5 of 6 (permalink) Old Yesterday, 03:35 PM
Drives: '12 Sorento '99 Acura 3.0CL '16 VW GTI
Quoted: 3 Post(s)
2012 3.5L oil pressure sender tool
I also have a sudden MASSIVE oil leak. Luckily, it is the oil pressure sender. Now I have the intake pulled off and can see the sender and, of course, the valley full of oil. But what tool is used to unscrew the sender? A regular socket of mine won't fit under the coolant pipe. Is there a unique extra thin wall socket for this???
mayers_929 is online now
post #6 of 6 (permalink) Old Today, 05:20 PM
Quoted: 3 Post(s)
I found out that a 24mm or 15/16" socket with swivel and extension does fit
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mayers_929
