2013 Sorento Alternator pulley replacement - Kia Forum
 2Likes
post #1 of 13 (permalink) Old 02-18-2017, 09:23 AM Thread Starter
Drives: 2013 Kia Sorento 2WD 2.4L LX, 2013 Kia Rio EX
belt tensioner pulley bolt
Hi all! Can someone tell me what is the size of the belt tensioner pulley bolt for 2013 Sorento 2.4?
Thanks.
Posted using a calculator and delayed by AT&T.
jas4u is offline
post #2 of 13 (permalink) Old 05-14-2019, 12:13 PM Thread Starter
Has anyone tried replacing the Alternator decoupler clutch pulley. Mine started to come out and shredded my serpentine belt. Good thing the belt was not cut while I was driving.
Attached is the photo.
Sent from my LG-US998 using Tapatalk
jas4u is offline
post #3 of 13 (permalink) Old 05-16-2019, 12:06 AM
Drives: Sorento 2012
Quoted: 21 Post(s)
Here is a link to the info you are looking for: https://kia.oemdtc.com/251/alternato...13-kia-sorento
Here is a link to the Kia removal tool for the pulley: https://kiaspecialtools.com/Catalog/Product/09373-27000
Now form reading the info it looks like if you have a T-50 Torx bit, a impact air gun and can hold on to the outside of the pulley, you should be able to remove the pulley without the Kia special tool.
nstoolman1 likes this.
jolt2 is offline
post #4 of 13 (permalink) Old 05-16-2019, 06:27 AM Thread Starter
Thanks a lot!
My biggest issue is removing the alternator. It is in between the power steering pump and the AC.
I wonder if you have the infor on this. Thr one on the link is not tye same as the engine setup that I have.
jas4u is offline
post #5 of 13 (permalink) Old 05-20-2019, 06:59 PM Thread Starter
Here is a link to the info you are looking for: []
Appreciate it boss.
Only issue is I have different engine compared to the picture. Also it didn't discuss whether to remove the Alternator or not. If it's going to be removed, how? If not, how to move the pulley on around 2 clearance.
jas4u is offline
post #6 of 13 (permalink) Old 05-21-2019, 02:53 AM
Quoted: 21 Post(s)
"3. Remove the alternator (A) from the vehicle.
Refer to the following section on KGIS for removal information:"
You must have missed this part chief.
Here is link to the KIA TSB that was also in that article: https://static.oemdtc.com/TSB/2012-126.pdf
You wanted know how to get the pulley off the alternator and this tells you how to do that. It also shows you what tools KIA has for the removal.
jolt2 is offline
post #7 of 13 (permalink) Old 05-21-2019, 11:58 AM Thread Starter
Dang it!
Thanks for pointing it out.
I saw a video of someone removing the alternator on the same model and it was a pain.
I wonder if there is a document regarding the right removal process.
Sent from my SM-G930F using Tapatalk
jas4u is offline
post #8 of 13 (permalink) Old 05-21-2019, 01:25 PM
Quoted: 21 Post(s)
Here is a link to the removal of the alt: Kia Sorento: Alternator Removal - Charging System - Engine Electrical System - Kia Sorento XM 2011-2019 Service Manual
It is the only info that I have found for the Sorento that is free on line. It is info from KIA and is only for the 2.4L engine but much of it can be applied to the V-6 also. If you click around on that page, you will work your way to the main index with full KIA service info for the vehicle. The TSB (technical service bulletin) that I link you to up above is for the 2013 2.4L, which is what you have listed in your vehicle information to the left of the forum page, although I could be wrong because my memory is not what it use to be. As for the picture in the TSB, sometimes a manufacture will use a generic picture as an example so you kind of have to fill in the blanks as you go. TSB are not a step by step, as the bulletins are written for the service mechanic and not for the DIY person.
jolt2 is offline
post #9 of 13 (permalink) Old 05-22-2019, 01:08 AM
VIM
Drives: White 2012 SX AWD
Quoted: 40 Post(s)
Found this on youtube for the 2.4L engine:
Looks like it's a big DIY project or it might be something left to a mechanic.
I thought it would be easier for the 2.4L than the 3.5L v6 but it doesn't appear so.
Looks like the alternator is just in front of the frame making it difficult to remove the bolts that hold it in place.
If you do this yourself, you may just want to replace the entire alternator. It may be cheaper than having the pulley replaced due to the additional labour costs.
If you did want to replace the pulley, you may want to look up a local alternator shop that will do it for you. They would have the pulley or could get it cheaper than you and definitely have to tools and be able replace it quickly and relatively inexpensive to going through the dealer. Or, buy the newer pulley as per the TSB and have the alternator shop replace it for you.
VIM is offline
post #10 of 13 (permalink) Old 05-22-2019, 08:21 AM
Drives: Silver 2012 Kia Sorento FWD Base with 2.4L
Quoted: 5 Post(s)
Yup. It's a real PITA to reach in and do it. My mechanic did it from the top on the shop's driveway because the garage was full tha day. He loosened and moved the coolant reservoir, power steering fluid tank and the strut mounting nuts on top to make some room to get in. The srut nuts removal was an odd thing for me to see but he was able to make a little room to work doing that. Took him maybe 45 minto install because he had to get in position, get the bolts in, adjust the belt then tighten.
DefMan is offline
Replacement Battery suggestion for Kia Sorento 2016 SX V6 mash.usnj 2016+ Sorento 38 05-07-2019 09:49 AM
2011 2012 2013 Kia Sorento all weather mats 3 row 5 piece OEM Free shipping scorpioevo8 Parts For Sale / Trade 0 02-02-2018 12:40 PM
Kia sorento oem 2011 2012 2013 cargo cover retractable cover shade blind scorpioevo8 Parts For Sale / Trade 0 02-02-2018 12:33 PM
ebay key replacement not recognised by 2011 Sorento mrbolano 2011 - 2013 (XM) Sorento Forum 5 09-01-2017 07:28 AM
