Whining noise - Kia Forum
post #1 of 4 (permalink) Old 04-09-2019, 01:41 PM Thread Starter
Drives: 2011 Sorento
Whining noise
My wife's 2011 Sorento has around 115,000 miles and has been making a whining noise for a while now. I replaced the serpentine belt, tensioner, and idler pulley but the noise remains. Now that it's getting warm out, we've noticed that the AC is not blowing cold air and she just said she noticed a burning smell. I'm thinking the AC compressor is bad, any ideas?
blang4d is offline
post #2 of 4 (permalink) Old 04-09-2019, 05:57 PM
Drives: 2019 Sorento SX AWD
Quoted: 67 Post(s)
That's not really much to go on. Does the whine change in pitch as you increase the throttle? It could be any of the belt driven accessories or even the idler pulley. On my 2013, I got a slight power steering pump whine and "jittery" steering feel at about 5 years old. I used a large syringe and a piece of tubing to "siphon" the power steering fluid out of the reservoir and refilled with this:
https://www.walmart.com/ip/Valvoline...allon/15125768 (this is the same fluid to use for changing your transmission fluid)
Then I started it up and turned the steering wheel lock to lock about a dozen times.
Shut the car down.
Repeat 3-4 times.
The whine disappeared and the steering returned to it's normal smooth operation.
If you suspect the A/C compressor, you can see if cycling the A/C on and off causes the whine to come and go.
2013 Sorento EX V6 AWD
2019 Sorento SX V6 AWD
2017 Dodge Charger Scatpack
2019Sorento is offline
post #3 of 4 (permalink) Old 04-09-2019, 06:02 PM
Quoted: 684 Post(s)
Describing a sound or noise is not easy, but you'll need to attempt a little better explanation, ......... does the pitch change with engine RPM at idle and driving, or does it change with speed, with it idling and the hood open does it come from the area of the aux belts?
Carefully try using a long screw driver with the back to your ear and the point on each aux device, alternator, AC compressor, power steering pump, tensioner roller, .......
Is the burning smell like plastic or rubber, is it coming from the area of the aux belt, ......... could be a seized AC compressor if it only happens when its turned on.
Take a video with your phone and post it to YouTube and the link here.
ron1004 is offline
post #4 of 4 (permalink) Old 04-19-2019, 03:14 PM
Drives: 2012 Sorento EX 3.5 V6
Quoted: 3 Post(s)
You've replaced the belt & 2 pulleys with the sound remaining.
You also have a lack of A/C.
If you turn on the A/C (engaging the clutch on the compressor) does the sound change?
Also note if you happen to loose RPM's when turned on at idle.
It could be the compressor clutch causing the problem, or other issues with the A/C system since you indicated a lack of cool air.
SorKia is offline
Whining noise at highway speed lours_polaire 3G (2012 - 2017) Rio 5 04-06-2017 01:13 PM
Whining or Harmonic Noise at Freeway Speeds exitleft 2016+ Sorento 2 05-16-2016 01:12 AM
The Mysterious Honking Noise redsoxmk 3G 2011 - 2016 Sportage 13 07-29-2015 09:27 AM
ughh, car making a whining noise when accelerating. help... Janks01 Kia Magentis & Optima Forum 3 11-08-2009 05:34 PM
Engine Whining when revved like a fan noise? DaveMac56 1G (1993 - 2002) Sportage 3 05-24-2008 09:48 AM
