Weird Issues with 2013 Sorento - Kia Forum
post #1 of 9 (permalink) Old 01-04-2019, 09:22 PM Thread Starter
Drives: 2013 Kia Sorento, 1998 For F-150, 2005 Ford Explorer, and 2018 Ford Explorer
So recently our 2013 Sorento has decided the at the clock and radio have decided to quit working (initially, it was intermittent but after hitting a pot hole it is constant). Additionally, the electric door locks will not open with the keyfob, however they do work with the buttons on the door. Also, the Airbag light is on. A friend of mine ran a scan and said the code indicated a 'ground fault' on the driver side seat sensor. I do not remember the exact code.
May question is this:
All of this sound like an electrical issue, possibly wire ran under the carpet to the seat. Could all of this be related and if so, what would be the best way to trouble shoot it?
John Benefield is offline
post #2 of 9 (permalink) Old 01-05-2019, 09:32 PM
Drives: 2019 Sorento SX AWD
Quoted: 67 Post(s)
It could be any number of things. I'd start with looking for corrosion on the battery terminals, then looking at all the grounding cables/straps, reseating the connector(s) on the ECU, etc. If a sudden pothole shot made it worse, then a loose connector or corroded/loose ground would be where I'd focus my efforts.
Cheers!
2013 Sorento EX V6 AWD
2019 Sorento SX V6 AWD
2017 Dodge Charger Scatpack
2019Sorento is offline
post #3 of 9 (permalink) Old 04-16-2019, 08:13 PM
Drives: 2012 Kia Sorento
Did you ever find a solution? My 2012 started doing this recently.
Cody Whitton is offline
post #4 of 9 (permalink) Old 04-17-2019, 08:40 AM
rejesterd's Avatar
Quoted: 141 Post(s)
Have you ever replaced the battery? That's the first thing I'd do, unless you've replaced it within the last 4 years or so.
If your battery is relatively new, then clean the connections with a wire brush and make sure they're very tight.
If that doesn't make any difference, I would assume you have a short somewhere. On older cars, this typically happens because some kind of weather stripping or seal is broken and allowing water to short out something.
rejesterd is offline
post #5 of 9 (permalink) Old 04-17-2019, 05:20 PM
Battery has been tested and checked for corrosion. Everything is fine.
My radio, clock and odometer started by having a memory restart whenever I started my car. Eventually the radio and clock started turning on and off while I was driving. Then my car fob stopped being recognized (battery is new) and I set off my car alarm when trying to start my car (as long as I don't lock my car it won't set the alarm off) now the radio and clock are completely dead and odometer resets every time I turn the car on.
I'm getting an oil change tomorrow from the dealer I purchased from and I really hope my extended warranty covers the repairs for this. Do you think I will have to replace entire radio? Or just replace a wire? Also when I turn on my headlights the lights on the radio do light up as of it works. So there is some power getting through.
post #6 of 9 (permalink) Old 04-17-2019, 05:41 PM
rejesterd's Avatar
Quoted: 141 Post(s)
That still sounds like a battery issue. How old is the battery? And how was it tested?
post #7 of 9 (permalink) Old 04-17-2019, 06:39 PM
The battery is at least 2-3 years old. I don't know exactly how it was tested, I was not there when it was. It was taken to Autozone. They said the battery is in excellent condition and putting out the right amount of voltage. I just checked the connections and the wires immediately around the battery - no sign of corrosion or damaged wires.
post #8 of 9 (permalink) Old 04-18-2019, 06:43 AM
rejesterd's Avatar
Quoted: 141 Post(s)
I would risk $100 to possibly save yourself some headaches and just replace the battery. The problem with getting it tested at Autozone is you have to drive there.. so the battery is charging during that time, and that can give a false reading. The best time to test it is in the morning after it's been sitting all night parked.
But maybe the dealer will check it out for free.. in which case, wait on their analysis.
post #9 of 9 (permalink) Old 04-19-2019, 02:59 PM
Drives: 2012 Sorento EX 3.5 V6
Quoted: 3 Post(s)
If the engine is starting fine, then I can't see it being the battery, especially if you've had it tested.
The fact that after you hit a bump, and more electrical items gave out on you, I would have to say that it's a loose ground that would be common to all these components.
Try to find a wiring diagram for your vehicle to try to source any commonality in everything that it giving out on you.
SorKia is offline
2014 Kia Sorento AWD V6 EX Electrical Issues? Nkutassy 2014 - 2015 Sorento Forum 0 06-09-2017 12:41 PM
Common Issues to look out for: 2012 Sorento V6 kia2012sorento 2011 - 2013 (XM) Sorento Forum 4 05-19-2017 06:53 AM
Map Update worth it for 2013 Sorento? biggins1978 2011 - 2013 (XM) Sorento Forum 0 08-25-2016 03:08 PM
UVO Upgrade from 1.MP.9.011 for 2013 Sorento djarvis8 2011 - 2013 (XM) Sorento Forum 0 05-05-2016 08:28 AM
2016 Sorento paint chipping issues with front door rocker panel stargirl 2016+ Sorento 2 03-24-2016 07:49 AM
