FYI Only - Both Catalytic converters are plugged $4400 to fix - Page 2 - Kia Forum
 1Likes
Closed Thread
post #11 of 11 (permalink) Old 11-25-2018, 08:33 AM Thread Starter
Drives: 2012 Sorento EX 2.4 GDI
Quoted: 33 Post(s)
Originally Posted by jolt2 View Post
Another place to check for cat's is the auto salvage yard. If the car was rear-ended or totaled from a side impact, the cat's may still be good. They would be OEM convertors so they would be California CARB CERTIFIED and should be about half the cost of new parts.
The big question that I see is what made the Cat's go bad to began with? If the cause of the problem is not fixed, the results are going to be the same (the convertors going bad). Convertors do not just go bad as stated above by MIA KIA 09. Rich fuel mixtures, silicone vapors, excessive motor oil usage, bad fuel and motor oil additives are just a few of the things that can kill a convertor.
1. My bad for not posting this as an FYI for those of you driving Sorento's of this year...
2. Not sure what the cause is of the cat's going bad with blockage as there are no error codes, all maintenance performed as required, only fuel additive was seafoam every oil change at 3 months over the last 2 years. About 90% highway mileage.
3. Not going to a salvage yard as there aren't any Sorento's anywhere...and not sure that is even proper or legal and aren't they scraped for the platinum?
4. Regardless, the cost is prohibitive vs the value of the car.
Thanks for all the feedback and best of luck with your sorento's moving forward. My feeling it has something to do with the way GDI engines work
MikDee likes this.
scoutyjones2 is offline
Closed Thread
ESC off and sudden lack of throttle response - TPS & ECU - TSB# KT2009042201 sornord Kia Carnival & Sedona 2006+ 86 09-11-2018 06:13 PM
Power steering high pressure hoses removal issue, both high and lower hoses. Learning 2G (1998 - 2001) Sephia 2 05-29-2018 07:07 PM
major power loss dbauto 2G (1998 - 2001) Sephia 4 05-18-2017 11:03 PM
Intermittent power loss of radio, digital clock and power sockets Herve Touche 2G (2003-2010) Sportage 2 02-23-2016 05:34 AM
'01, loss of power after hard brake Aaiiee 1G (1993 - 2002) Sportage 7 01-15-2008 09:01 AM
