Power Steering Fluid Flush - Kia Forum
 1Likes
post #1 of 11 (permalink) Old 04-17-2018, 08:12 AM Thread Starter
Drives: 2012 Sorento EX-V6 Luxury
Quoted: 25 Post(s)
I have a 2012 Sorento 6-cylinder. It has 245,000km/152,000m. I hear various opinions on the frequency of Power Steering Fluid Flush. Some input please
Eh!
2012 KIA Sorento EX-V6 Luxury
geeksrus is offline
post #2 of 11 (permalink) Old 04-17-2018, 02:01 PM
Drives: 2015 K900
Quoted: 6 Post(s)
Most people forget to even check the fluid level, let alone replace it. Generally, replacing the power steering fluid every three years or so is a good idea. You can even do it yourself with a clean turkey baster. Just be sure to use the right fluid for replacement. Doing this every few years is a lot cheaper than replacing a dead power steering pump.
Lou O. likes this.
Zathras is offline
post #3 of 11 (permalink) Old 06-11-2019, 01:46 PM
bwbogie's Avatar
Drives: 2011 Kia Sorento LX 3.5L V6
I highly recommend changing the fluid every 40k. I never knew that changing the power steering fluid was a thing, until my pump died a couple weeks ago. The fluid should be clear, and not brown, like mine was. Metal shavings accumulate over time and destroy the pump if the fluid is not changed. Power steering fluid is cheap, a pump is not. Luckily I changed it myself to save on mechanic fees, but a pump was almost $300 Canadian.
bwbogie is offline
post #4 of 11 (permalink) Old 06-11-2019, 05:58 PM
Drives: 2013 Kia Optima LX
I have actually never had a power steering pump fail... but I have replaced many defective power steering sectors/racks.
Every 3-5 years should work well for most systems.
LincTex is offline
post #5 of 11 (permalink) Old 06-12-2019, 10:00 AM
Drives: Silver 2012 Kia Sorento FWD Base with 2.4L
Quoted: 5 Post(s)
There are videos on youtube. I flushed mine by jacking up the front, having someone turning the steering wheel and disconnected the return line to empty the fluid in a tub. Then added new PSF and moved the steering wheel around while filling it up before hitting the road. Very easy.
DefMan is offline
post #6 of 11 (permalink) Old 06-12-2019, 04:21 PM
Quoted: 129 Post(s)
Not sure about Kias but some cars can and do use ATF for PSF.
It usually is as easy as DefMan said.
dubber09 is offline
post #7 of 11 (permalink) Old 06-12-2019, 05:32 PM
Drives: 2007 Rondo and 2000 Tacoma
Quoted: 16 Post(s)
It might not be the same for later models but my 2007 can use Ravenol SSF.
Itís made in Germany and it meets all Kia requirements.
Old ní slow is offline
post #8 of 11 (permalink) Old 06-12-2019, 07:03 PM
Lou O.'s Avatar
Quoted: 27 Post(s)
Exactly what I do. Fill up dixie cups with the old fluid then you will know how much to reinstall. (ex. 3 out = 3 in) Purchase a good quality synthetic power steering fluid with conditioners for the seals.
You can do this yourself. Very easy.
Lou O. is offline
post #9 of 11 (permalink) Old 06-13-2019, 09:33 AM
Quoted: 5 Post(s)
Yes, exactly. I flushed with ATF then refilled with Kia PSF 3.
DefMan is offline
post #10 of 11 (permalink) Old 06-18-2019, 12:29 PM
Drives: Kia Sorento 2012
So on 2012 Sorento can I use different power steering fluid , and what’s the exact amount will take , just making sure i do right way
Besfort is offline
Power steering high pressure hoses removal issue, both high and lower hoses. Learning 2G (1998 - 2001) Sephia 2 05-29-2018 07:07 PM
Power Steering Fluid shock 3G (2006.5+) Magentis & Optima 2 04-17-2018 09:46 AM
Power Steering Fluid Question 12RondoEX Kia Carnival & Sedona 2006+ 4 05-04-2016 05:47 PM
Power Steering Fluid Flush bigbear75 Cerato (2003 - 2008) & Spectra5 (2004) 6 12-21-2008 09:02 PM
Squealing belt - Power steering fluid? Xenomorph 1G (2001-2005) Rio 6 10-09-2008 04:38 PM
