2013 Sorento headlight issue - Kia Forum
 2Likes
post #1 of 14 (permalink) Old 04-25-2017, 06:56 PM Thread Starter
Drives: 2013 Soul Base, AT, Titanium and 2013 Sorento, 4 cyl, Blue
Quoted: 13 Post(s)
So the passenger headlight doesn't work on the Sorento. Probably bulb I figure as I run the headlights all the time since we don't get Day Time Running lights. Dumb move for the USA market but it is what it is. Pull the cover behind the bulb to find the connector at the base of the bulb has melted away. Obviously a high resistance connection that has heated and failed. Where in the heck do you find replacement connectors (2 pin) that will fix this?
TexasDave is offline
post #2 of 14 (permalink) Old 04-25-2017, 07:27 PM
Drives: 2013 Sorento Ex V6
Quoted: 44 Post(s)
Does not help your issue, but my 2013 Sorento has day light Running lights. It has a switch on the turn signal lever to turn on/off. Mine is a EX, but as I remember the LX does not have them. Is that your model? Please post back if you find connectors, might come in handy some time.
meebers is offline
post #3 of 14 (permalink) Old 04-25-2017, 08:20 PM
Quoted: 96 Post(s)
Check on Rock Auto under headlamps/sockets.
Hth
nstoolman1 is offline
post #4 of 14 (permalink) Old 04-26-2017, 03:28 AM
Drives: Sorento 2011
Quoted: 12 Post(s)
These things are readily available. You can get one at a junkyard, eBay or Amazon. Search for "H11 pigtail".
Soulsurvives is offline
post #5 of 14 (permalink) Old 04-27-2017, 05:34 PM Thread Starter
Quoted: 13 Post(s)
Thanks for the tips. Didn't think it would be at an aftermarket auto parts place. The local junkyard says no to butchering the wiring harness. Oh yeah mine is the LX- no DRLs.
post #6 of 14 (permalink) Old 05-31-2017, 01:39 AM
Drives: Sorento 2012
Quoted: 21 Post(s)
KIA knows of the problem and has a "Voluntary Service Campaign" to fix the problem. In the letter I received, it states "Kia has advised its authorized dealers to replace the halogen low beam connector wiring harnesses on the affected vehicles. This work will be performed at Kia's expense at no cost to you." The letter is dated May 5, 2017. If the dealer does not help you then call Kia's Consumer Assistance Center at 1-800-333-4542 in U.S. or through the owner's section of Kia's web site.
jolt2 is offline
post #7 of 14 (permalink) Old 10-15-2018, 12:09 AM
Hi jolt2, I am not seeing much about this voluntary service campaign online, many people are getting declined service. Was this letter mailed to you? I will call Kia soon but I am wondering if this is something you had done or if you got the letter. Thanks.
bboi68 is offline
post #8 of 14 (permalink) Old 10-15-2018, 05:23 PM
Apparently, the voluntary service campaign does not apply to my specific VIN, it’s a 2013 Kia Sorento. This is what I was told by 1800- Kia
bboi68 is offline
post #9 of 14 (permalink) Old 10-17-2018, 12:36 AM
Quoted: 21 Post(s)
bboi68, the letter was mailed to me from KIA. I looked at the letter again and see that it said 2011 and 2012, some model specific. So not everyone got the letter as it was VIN specific. On the bill it states: 2 92165-1U000QQK BULB HOLDER SERVICE then below that is; COMPLETED SC149 LOW BEAM CONNECTOR RECALL
Here is a link to the part #92165-1U000QQK : https://www.quirkparts.com/oem-parts...-921651u000qqk
And here is a link that speaks about the SC149 recall with information about other things that can cause bulb failures: https://www.kia-forums.com/2011-2013...tly-burns.html
On a side note: I had a 2000 Nissan Quest van that had the light bulb socket failure on both headlights. When the first bulb stopping working, I thought it was a burnt out light bulb. When I went to change the bulb, I seen the old bulb was still good. I tested for voltage at the socket and had none. Tested for voltage behind the socket and was good. I went to the parts store and bought a new socket, cut the old socket out, soldered and shrink tube the wires to the new socket, and The headlight worked again. About a year later the other headlight stopped working and I just went and replaced the socket and it fixed the light. A bad socket is nothing new to me and as cars are made cheaper, well corners get cut as nothing is made any heavier than it absolutely needs to be.
and some additional info was found:
Bulletin Number: VSC149TSBR1
Bulletin Date: 05-12-2017
Component: 114000 electrical system:wiring
Summary:
Tsb: sc149r1 - halogen headlamp low beam connector replacement (sc149) - this bulletin provides the procedure to replace the halogen headlamp low beam connector wiring harnesses on some 2011-2012my sorento (xma) vehicles, produced from apri
nstoolman1 likes this.
jolt2 is offline
post #10 of 14 (permalink) Old 10-17-2018, 01:40 AM
Thank you so much for the help Jolt2, that is exactly my plan. My headlights have always burned up sooner than they would on other cars, but for the last few months it turns off randomly, and will turn on when I play with the harness cables. My plan originally was just to solder on a new h11 pigtail but I was hoping kia may have had this voluntary service campaign available to me. Oh well, I think I am going to try one of these aftermarket ceramic h11 sockets, apparently they withstand heat better. Thanks again for the help Mr. Jolt2, I hope this thread helps others in the same boat as it helped me.
bboi68 is offline
2012 Sorento Headlight wiring Jeremy Beeson 2011 - 2013 (XM) Sorento Forum 5 01-29-2019 01:40 AM
2013 Sorento V6 Engine Failure scottrell8 2011 - 2013 (XM) Sorento Forum 16 12-14-2017 03:59 AM
Headlight Issue Sidewayseght 2011 - 2013 (XM) Sorento Forum 1 12-12-2015 06:40 AM
2013 Sorento "computer not going to sleep"? CR0330 2011 - 2013 (XM) Sorento Forum 1 12-04-2015 07:24 AM
second thoughts on a 2013 V6 Sorento nwill002 2011 - 2013 (XM) Sorento Forum 2 10-19-2015 08:39 AM
