My engine just stopped under steady speed - Page 2 - Kia Forum
 2Likes
post #11 of 26 (permalink) Old 02-20-2018, 08:02 AM
gee6's Avatar
Quoted: 65 Post(s)
Originally Posted by rainmann View Post
And where and what do you mean by more than one chain at the front of the engine?
I mean 3 chains. See schematics attached; Chains A, B, C with associated tensioners. If you check with suppliers you will typically see them listed as a set (about 100 here).
ron1004 likes this.
gee6 is offline
post #12 of 26 (permalink) Old 02-20-2018, 10:09 AM Thread Starter
Drives: Kia Sorento 2006
Quoted: 10 Post(s)
There is no ratation parts at the engine side of the starter.. The only thing that rotate are the starter it self
rainmann is offline
post #13 of 26 (permalink) Old 02-20-2018, 02:14 PM
Quoted: 704 Post(s)
You'll need to get the starter fixed and then do a compression test.
ron1004 is offline
post #14 of 26 (permalink) Old 02-21-2018, 04:30 AM
gee6's Avatar
Quoted: 65 Post(s)
And by the way... All u guys and girls, if you have experienced what i wrote in my very first at this post...abt the engine that wendt in limp mode and stopping a LOT....,.I can now confirm the fact that it was allways the tank mounted filter that glogged uop..For some reason, is it according to my local Kia dealer, that the producer of the diesel tank at my specific model,anyway have used some kind of sedement or stuff inside the fuel tank,that realeases something that glog the filter
Yes, but that does not exactly explain the symptoms you described when it stopped and since. In any case the clogged tank strainer is easily fixed (via the hatch access under rear passenger seat). If the fuel pressure drops (eg because of clogged strainer) below a certain level, the ecu will prevent engine running in that condition.
In any case Kia UK have been replacing fuel tanks for this very reason on Free-of-charge basis and is well documented. (Kia Sorento fuel tank delamination)
You may also need to replace fuel filter (in engine bay) and hope no particles have made it as far as the high pressure pump mounted on the engine - driven by one of those chains mentioned earlier.
gee6 is offline
post #15 of 26 (permalink) Old 02-21-2018, 06:57 AM Thread Starter
Quoted: 10 Post(s)
I know abt the tank issue... I have controll on that... But for the guy that insinuate i should fix my starter??? I wrote that the engine died while fully engaged... THAT tells ME that the starter at that point, are not engaged and do not have nothing to fo whit MY problem... As an update, i can tell that i yesturday took a diagnostic check and ended up whit DTC P0340 and P0336 ALL INTERMITTENT... I also took some pictures...is there somewhere i can upload them???
rainmann is offline
post #16 of 26 (permalink) Old 02-21-2018, 07:07 AM Thread Starter
Quoted: 10 Post(s)
This is something from the reg cain guiding that fell out when i opened the cower for the registry ?
rainmann is offline
post #17 of 26 (permalink) Old 02-21-2018, 07:09 AM Thread Starter
Quoted: 10 Post(s)
I was not able to upload non of my pictures...Why?
rainmann is offline
post #18 of 26 (permalink) Old 02-21-2018, 07:18 AM
Drives: 2006 Kia Sorento
Quoted: 89 Post(s)
Hi there boys and girls... I have this problem whit my plugs are getting soated and i am not able to throttle up from idle speed whitout the engine misfire and stops. Can somone please tell me whats going on??? I think it could be either the catalyst melt down or the fuelpump that have given up?? How is the easiest way to find out of this?? It happend suddenly and for no abnormal use... Thanks
Soot is usually caused by to much fuel I would check fuel pressure. The fuel pressure regulator is located at the back of the pass. side fuel rail. I wouls start at the basic test before checking electrical problems.
rhandwor is offline
post #19 of 26 (permalink) Old 02-21-2018, 10:36 AM
Quoted: 704 Post(s)
No I did not insinuate anything, I made a recommendation that you perform a compression test, and if it was low you then have confirmation that there's a serious internal issue with the engine, such as valve timing, and any start attempts would be futile.
I'm not sure if its a language misunderstanding, but it is very difficult to understand what diagnostic approach you are following, if any.
You stated that the compression was OK, but also state that the starter is not rotating the engine, which leads to an obvious question, how did you do a proper compression test without the starter.
Your description of the problem is not easy to read, and what looks like inappropriate use of "?" makes it more confusing.
You can upload the pictures directly to this site - scroll down and use the "Manage Attachment" button.
ron1004 is offline
post #20 of 26 (permalink) Old 02-21-2018, 05:16 PM
gee6's Avatar
Quoted: 65 Post(s)
@ron1004
Sorry, but I think merging of threads 5 years apart has confused the issue. Can we concentrate on the current issue? My bad, I missed it earlier when I replied about the tank issue.
@rainman
Taking into account that the starter/flywheel engagement is at one end of the engine and that the crankshaft/camshaft motion is at the other end of the engine, you really need to determine if the engine is actually capable of being turned via the crankshaft (but carefully). This will probably mean removing the glow plugs (it's a diesel guys) which is not necessarily easy but, given your earlier posts about 'oiled plugs' you probably know this. (Or we are talking completely different cars?). In the same instance you should be able to observe if the camshaft is turning at the same time.
Just based on what we know so far I suspect either:
Seized engine and snapped crank (it happens)
broken timing gear
(or both by now)
Since you state the camshaft chain is in place and "ok", a broken lower chain would still disconnect crank from camshaft.
Attempting to rotate the engine via the camshaft, if all were intact, should be virtually impossible due to the high compressions involved.
But, any attempt at diagnosis from the data available is really unreliable.
Inevitably, after all the messing about with the starter, you are seriously going to have to look at resetting the timing just to ensure that nothing goes bang if it does ever start.
gee6 is offline
2007 2.4l engine noise puddleglum2 Kia Carens & Rondo Forum 6 04-30-2018 01:58 AM
normal AT "drag" when off gas pedal? 2008 lxv6 Kia Carens & Rondo Forum 10 08-06-2015 12:06 PM
Error Codes Raven1210 2G (2006 - 2011) Rio & Rio5 0 06-20-2007 12:15 AM
Error Codes Raven1210 1G (2001-2005) Rio 0 06-19-2007 11:57 PM
