Timing Chain on 2008 3.3L Sorento LX - Kia Forum
post #1 of 13 (permalink) Old 06-28-2019, 06:09 PM Thread Starter
Drives: 2008 Kia Sorento LX 3.3L V6
Quoted: 9 Post(s)
The timing chain doesn't have different colored links on the chain (that I can see), so there is really no way to use the chain to align with the marks on the sprockets. Has anyone done a timing job on this model?
Mr.Scarface is offline
post #2 of 13 (permalink) Old 06-28-2019, 07:19 PM
Lou O.'s Avatar
Quoted: 27 Post(s)
Although this could be done, its not industry standard.
What is important is the teeth on each cam sprocket and their relationship to each other and the crank shaft sprocket.
Cam timing is very important. Be sure you get it correct.
Get ahold of a good repair manual and read up on cam timing.
Good Luck!
Lou O. is online now
post #3 of 13 (permalink) Old 07-07-2019, 03:36 AM Thread Starter
Quoted: 9 Post(s)
Good Luck!
I have the Kia manual for the 2008 Sorento.
This issue Im having is resetting the timing. The Timing Marks are off on the Sprockets so the Intake and the Exhausts do not line up. I currently have the crankshaft set at 0 and Cylinder #1 is a Top Dead Center. Questions is do I need to loosen the camshafts bearing caps and manually turn the sprockets (with the chain off) to set them to the right marks?
post #4 of 13 (permalink) Old 07-07-2019, 08:50 AM
Lou O.'s Avatar
Quoted: 27 Post(s)
Don't loosen the cam caps. Not necessary. You can rotate the cams via the shaft itself. Look for a set of flats somewhere on the cam shaft that will allow you to put a wrench on to rotate it. Both the intake and exhaust cams should have these flats. You need to overcome the valve spring force, but that should not take too much effort. You need to know where the 'dots' need to be in relationship to the crank at TDC. Hope this helps!
post #5 of 13 (permalink) Old 07-07-2019, 06:59 PM Thread Starter
Quoted: 9 Post(s)
I can move the cams via the 14mm bot in the front of each. AT TDC, The whole intake cam on the left side (Cyclinder #1 ) moves and I can put it at the right spot for the marks. The exhaust cam freely spins by hand because only the front rocker is moving. On the right side, I going to assume I'm going to have to move cylinder #4 (intake) to TDC to align that side.....correct?
post #6 of 13 (permalink) Old 07-08-2019, 10:01 AM
Lou O.'s Avatar
Quoted: 27 Post(s)
Don't move the crank. Both banks of cams need to be in synchronous relationship with the crankshaft or the engine may not run smoothly, or not at all. Rotate the cams only. Because these engines are 'interference' designed, very low squish area (aka valves can hit pistons) use due care when spinning the crank or cams. A piston at TDC (either intake or exhaust) can contact the valves if your not careful.
Valve stems can bend easily. Don't force things into place! Good luck. You can do this!
post #7 of 13 (permalink) Old 07-09-2019, 12:29 AM Thread Starter
Quoted: 9 Post(s)
#1 How do I get the right side aligned if they are stuck (hitting the pistons)? Do I go back 45 degrees (counterclockwise) then move forward?
#2 On the left side, do I worry about only the first rocker moving on the exhaust after I align the intake side? (remember, cylinder 1 is at TDC.)
Edit: I saw a video for another engine and the guy said I need to move the crankshaft 90 degrees from TDC before moving the cams. Move it back after adjusting the sprockets.
post #8 of 13 (permalink) Old 07-09-2019, 08:34 AM
Lou O.'s Avatar
Quoted: 27 Post(s)
In this case yes, move the crank and then move it back. Other ways which work are to align the cams with the heads off the block. Or you can loosen the cam caps to prevent the cam from opening the valve all the way. Normally 10mm will suffice, but all OHC engines are different. Your second question, depends on the firing order and how the cylinders are numbered....
I prefer to align the cams with the heads off the block. But, not always possible.
ps....do this without the timing belt installed or you will never get the proper time.
post #9 of 13 (permalink) Old 07-10-2019, 02:58 AM Thread Starter
Quoted: 9 Post(s)
Besides the timing marks, is there a way to know if the timing is done properly (besides putting everything back together...and starting)? Looking at the camshaft themselves?
post #10 of 13 (permalink) Old 07-10-2019, 10:10 AM Thread Starter
Quoted: 9 Post(s)
Well...background. This Sorento died on my daughter about 8 months ago while driving. I've not had time to really look at it after taking everything off after I figured out I need to remove the timing cover. A couple of broken chain guide, tensioner, and tension arm on both chains (but no broken chain) led me to believe the chain or chains go loose.
But trying to do what I was doing in this thread, I found the real culprit after I removed one of the chains. I mentioned earlier that the exhaust cam was only moving one of the lobes and moved freely. Freely by hand. Yep, a broken camshaft seems to be in the issue. I'm going to remove the bearing caps and verify. I'm just trying to find the sequence to remove them.
