Engine shuts down while driving - Kia Forum
post #1 of 76 (permalink) Old 06-23-2006, 01:12 PM Thread Starter
Ilan's Avatar
My turn to visit the dealer, the Diesel Engine shuts down under load. Can be dangerous, happened today while I was passing a slower car.
It happened first time last week. The dealer could not find any thing wrong. This time the CHECK engine light is on, so the computer registered the fault.
Does some one has experience with such fault?
Ilan is offline
post #2 of 76 (permalink) Old 06-23-2006, 03:05 PM
Drives: 2007 Optima, 2007 Sorento
Please post the fault number(s) from the computer.
Schnauzer is offline
post #3 of 76 (permalink) Old 06-23-2006, 03:05 PM
Murphwiz's Avatar
There was a recall for ECU wiring, if faulty it caused similar faults, did your car have recall?
Murphwiz is offline
post #4 of 76 (permalink) Old 06-23-2006, 11:09 PM
Drives: 2004 Kia Sorento
Hi Ilan!
Same symptoms I heard from one Sorento owner. His engine stops when he tries to accellerate and the "check engine" light is also showing too. The culprit he told me is his dirty fuel filter. After this incident, his dealer recommended changing the fuel filter every 20,000 kms
Jollypierre is offline
post #5 of 76 (permalink) Old 06-24-2006, 12:34 AM Thread Starter
Ilan's Avatar
I don't have a way to get the number I need to visit the dealer.
I never heard of the recall, my Sorento is 2005 model. The dealer will have to explain if there was a recall and I have never heard of it.
The Diesel filter was replaced 3,000 km ago.
Ilan is offline
post #6 of 76 (permalink) Old 06-24-2006, 06:00 AM
Well, could be another problem. But if it's me, I wouldn't mind asking my dealer again to change the fuel filter. Who knows, it might solve the problem as it did to the other guy. Besides as per what the guy told me, it seems they're not changing the fuel filter when we drive-in our Sorento for service. I personally haven't seen it in my last service bill.
post #7 of 76 (permalink) Old 06-25-2006, 02:58 AM Thread Starter
Ilan's Avatar
The Sorento is with the dealer, first thing they suspected the fuel filter until I told them it was replaced recently.
The computer gives the following fault code: P1188 - Fuel pressure, leakage.
When the technician checked the parameters when the fault occurred, he got all the data, one item seems odd: the engine's temperature read out was -25.7 when it happened, murphwiz any advise here?
Ilan is offline
post #8 of 76 (permalink) Old 06-25-2006, 06:54 AM Thread Starter
Ilan's Avatar
The plot thickens.
The dealer did not find any thing wrong with the engine. They know there is a problem because I handed them the truck with the check engine on, but they did not find any thing wrong with the fuel system.
At another forum Murphwiz linked this site (thanks mate):
http://210.120.123.38/kme_viewer/default.asp
If you look at the site, look for the symptom - Engine stalls. You will see that a suspected culprit is the Coolant temperature sensor. With the false reading that we got from the on board computer, it makes sense to start with it, so the dealer ordered one for tomorrow.
Interesting enough is that he only ordered the sensor because I printed the page for him
Murphwiz any advise?
Ilan is offline
post #9 of 76 (permalink) Old 06-25-2006, 10:47 AM
Murphwiz's Avatar
If coolant temp sensor goes bad, you collant temp gauge will be inop, but the engine management should spot this and go over to a pre programmed map according to run time, as it knows how quick the car should warm up.
Won't be perfect, but should keeps things running with very little ill effect.
Thats how it should work from a cold start anyway, not sure what happens if it suddenly dies.
The figure quoted sounds like default reading, so could be open circuit to sensor, ecu, or something else!
Did they mention the ecu wiring harness issue? it may have only affected RHD vehicles.
Murphwiz is offline
post #10 of 76 (permalink) Old 06-25-2006, 02:12 PM Thread Starter
Ilan's Avatar
I asked about it, no recall for me.
I drove the car all day, all OK. Will replace the CTS tomorrow.
It is a tricky one.
Ilan is offline
what is oil type sorento use ? picard12 2014 - 2015 Sorento Forum 145 07-29-2018 03:08 PM
Engine misfire or vibration when first driving in the a.m GDI 3.3L Fan 2014 - 2015 Sorento Forum 22 09-06-2017 09:15 PM
2010 Kia Rio 75k Miles - Engine Dead DavidLezette 2G (2006 - 2011) Rio & Rio5 2 08-06-2015 05:00 PM
06' Sore-tow, Engine died while driving. chas-charlie 2003-2010 Sorento Forum 4 06-07-2015 10:06 PM
Engine Died While Driving. Timing Belt? stevembe430 Kia Sportage Forum 4 03-08-2008 01:49 PM
