Fuel Pump Assembly Replacement '08 Sorento LX - Kia Forum
 3Likes
post #1 of 12 (permalink) Old 05-13-2019, 12:11 PM Thread Starter
kial98's Avatar
Drives: '08 Sorento, '18 Civic Type R, '90 Vortech Supercharged TransAm, '03 VF-34 WRX, '97 Del Sol SI
The 2008 Sorento Owner's Manual recommends replacing the fuel filter every 60,000 miles/48 months (Normal Service) or 36,000 miles/36 months (Severe Service).
The fuel filter is located inside the fuel pump assembly. I found a complete new OEM pump assembly for ~1/3 MSRP and chose to replace the entire assembly while i had access:
Here are most of the tools you will need. The blue pliers are fuel line disconnect pliers:
Hyundai Part No. 09310-2B200 Fuel Pump Plate Cover Wrench
Have a fire extinguisher on hand AND WEAR SAFETY GLASSES any time you work around fuel:
(Continued below)
ID:	105400   Click image for larger version
ID:	105402   Click image for larger version
Name:	Ratchet On Ring Tool.jpg
ID:	105404   Click image for larger version
swampdodo likes this.
kial98 is offline
post #2 of 12 (permalink) Old 05-13-2019, 12:38 PM Thread Starter
kial98's Avatar
Disconnect the fuel pump electrical connector. Try to start the engine until it stalls to use up any fuel remaining in the lines. Remove the fuel filler cap. Disconnect the negative battery cable. I like to put a nitrile glove over the end of the ground cable to ensure no accidental contact.
Put a rag under the fuel line. Remove the orange fuel line connection lock and disconnect the line using the fuel line pliers to compress the blue tabs on each side of the fuel line connector. I only had an ounce or two of gas leak out onto the rag.
Remove the black rubber ring that covers the fuel pump assembly retaining ring to see this:
Use a marker to show the original position of the retaining ring with respect to the fuel tank. Position the Hyundai cover removal tool in place in four of the ring holes and tighten the thumb screws on the top of the tool:
Use a 1/2" drive ratchet to loosen and remove the retaining ring. I had to remove and reposition the Hyundai tool twice due to interference with the side of the access opening. It took ~1-1/2 complete turns of the ring and quite a bit of force to remove it. Clean the inside of the ring and apply a little anti-seize to make it easier to reinstall and remove next time.
(Continued)
Name:	Bat Disconnect.jpg
ID:	105408   Click image for larger version
ID:	105410   Click image for larger version
ID:	105412   Click image for larger version
Name:	Ring Tool In Place.jpg
kial98 is offline
post #3 of 12 (permalink) Old 05-13-2019, 12:58 PM Thread Starter
kial98's Avatar
Retaining ring off:
Vacuum/clean up any debris around the top of the pump before you remove it. Be carefull not to damage the fuel level mechanism when you remove/reinstall the pump. Old pump out:
Install the new pump and secure it with the cleaned retaining ring (with a little anti-seize applied). My new pump would not seat far enough down to allow installation of the retaining ring. While messing around with my old pump later i realized that the silver top plate is spring loaded to the rest of the pump assembly. You can compress the plate down to allow installation of the retaining ring.
Reinstall the big black rubber ring over the retaining ring, reconnect the fuel line and electrical connectors. Reconnect the negative battery cable. Start it up to check operation and for any leaks. Re-secure the access cover with the screws.
ID:	105416   Click image for larger version
Last edited by kial98; 05-16-2019 at 07:32 PM. Reason: Update retaining ring install.
kial98 is offline
post #4 of 12 (permalink) Old 05-13-2019, 05:22 PM
rejesterd's Avatar
Quoted: 141 Post(s)
Nice post, thanks.
I actually bought the filter, I just haven't installed it yet. Did you get a look at how bad your old filter was?
Also, do you have a link to the pump assembly you bought?
Thanks.
rejesterd is online now
post #5 of 12 (permalink) Old 05-13-2019, 05:50 PM Thread Starter
kial98's Avatar
Originally Posted by rejesterd View Post
Nice post, thanks.
Thanks.
I haven't opened up the old assembly yet but will report back my findings if/when i do.
Bought the pump from this online seller. Looks like they don't have another pump in stock right now but you might want to keep watch for another one to come up:
https://www.ebay.com/sch/oemtradersi...72.m2749.l2654
UPDATE - I see you have a 2016. I'm not sure how much of this procedure applies to that model year.
kial98 is offline
post #6 of 12 (permalink) Old 05-13-2019, 06:52 PM
rejesterd's Avatar
Quoted: 141 Post(s)
Yeah, I probably won't buy the full assembly.. I was just curious about how bad the filter might look.
post #7 of 12 (permalink) Old 05-13-2019, 07:43 PM Thread Starter
kial98's Avatar
Here you go. Little visible debris on the filter inlet strainer and most of it was easily removed with a toothbrush:
Very little debris in the bottom of the bucket either:
Guess i won't worry about the fuel filter/pump for another 11 years. And I have a spare fuel level sender and pump
ID:	105396   Click image for larger version
rejesterd likes this.
kial98 is offline
post #8 of 12 (permalink) Old 05-14-2019, 08:26 AM
Drives: 2008 SORENTO EX
Quoted: 6 Post(s)
Maybe it is just me, but can't seem to 'see' the images...
Anyone else?
swampdodo is offline
post #9 of 12 (permalink) Old 05-14-2019, 08:32 AM Thread Starter
kial98's Avatar
Anyone else?
Weird. Pretty sure they were there yesterday. Put them back again plus left the thumbnails this time.
kial98 is offline
post #10 of 12 (permalink) Old 05-14-2019, 10:05 AM
Quoted: 6 Post(s)
Thanks...actually, I meant your first, second and third post...don't see the images there.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
98 sportage fuel pump replacement bolt trouble... gordesky1 1G (1993 - 2002) Sportage 14 01-11-2018 05:17 AM
2001 kia rio fuel pump fitting problem jrdsyyn 1G (2001-2005) Rio 5 07-30-2016 07:50 PM
Fuel tank replacement asarangan 1G (2001-2005) Rio 0 07-29-2016 07:25 PM
fuel pump priming issue vitaminK 2G (1998 - 2001) Sephia 5 01-27-2011 07:23 AM
02 sportage wont start no fuel! pump is turning on dukeduster 1G (1993 - 2002) Sportage 55 05-14-2007 07:47 PM
