09 Sorento Rear Differential - Kia Forum
post #1 of 15 (permalink) Old 05-10-2019, 09:04 PM Thread Starter
Obliv51's Avatar
Drives: 09 Sorento EX 3.8 RWD
I want to change my rear diff fluid but I have heard that the rear needs to be jacked up 8" off the ground or there will be insufficient amount of fluid in the diff which will cause early failure. Is this true? I have posted this before but it was deleted by admins because I didn't update profile. I have not seen this done on any other makes and this is the first time I have ever heard of such of thing. Any thoughts?
Obliv51 is offline
post #2 of 15 (permalink) Old 05-10-2019, 09:39 PM
kial98's Avatar
Drives: '08 Sorento, '18 Civic Type R, '90 Vortech Supercharged TransAm, '03 VF-34 WRX, '97 Del Sol SI
There was a Kia Tech Times #Kt2005022817 issued on 28 Feb 2005 that said "to position the rear wheels at least 8 inches higher than the front wheels. This procedure is required to ensure that the rear axle housing is filled with the specified volume of gear oil (1.6L or 54 oz.)..."
I don't know if this applies to 2008/2009 and can't remember if i bothered to elevate the rear wheels when i changed the gear oil. For the rear of my 2008 3.3L 4WD LX I just removed, measured and replaced 1.69 Qts. of gear oil. For the front the Tech Times says the vehicle can be level. I removed, measured and replaced 1.37 Qts. from the front.
So far, so good.
kial98 is offline
post #3 of 15 (permalink) Old 05-10-2019, 10:06 PM Thread Starter
Obliv51's Avatar
How long ago did you replace your oil?
You can do it!
Obliv51 is offline
post #4 of 15 (permalink) Old 05-11-2019, 07:33 AM
rejesterd's Avatar
Quoted: 141 Post(s)
I've never heard of that, but it does make sense to me if the rear diff's fill port sits low on the housing and there's a horizontally-spinning gear that sits above the fill port. I don't know what the 2009 looks like inside, but a rear diff doesn't typically have a high-positioned bevel gear like that. That's the only reason I can see for tilting it. As long as all the gears dip below the oil level line, I think you're good. But really, the way to be sure is just find the capacity spec in your manual and make sure that amount gets in. If it doesn't, then I suppose I would tilt the car in that case. I doubt Kia would just make up a story like that if it didn't have some validity to it.
rejesterd is offline
post #5 of 15 (permalink) Old 05-11-2019, 08:24 AM Thread Starter
Obliv51's Avatar
That sounds logical/ideal. I guess what I will do is start off with it level. Drain. Measure. Try to put in spec amount of oil. When it fills up, see how much I have left in container. Determine how much I used. If not at spec amount, then jack up rear to 8" and finish. Miss anything? May need to get some 6 ton Jack's for the the axle.
You can do it!
Obliv51 is offline
post #6 of 15 (permalink) Old 05-11-2019, 11:41 AM
rejesterd's Avatar
Quoted: 141 Post(s)
I think 3 ton jack stands are fine. Just put some chocks on the front tires for safety, and make sure you take the fill plug off before draining it.
..and get ready for some really stinky oil to come out.
post #7 of 15 (permalink) Old 05-11-2019, 03:54 PM
kial98's Avatar
About 13,000 miles ago when the vehicle had ~49,000 miles on it.
kial98 is offline
post #8 of 15 (permalink) Old 05-11-2019, 04:58 PM
kial98's Avatar
Attached is the referenced Tech Times (Hopefully):
Name:	Tech Times 001.jpg
kial98 is offline
post #9 of 15 (permalink) Old 05-11-2019, 09:59 PM Thread Starter
Obliv51's Avatar
I tried my three ton Jack's and they weren't tall enough unfortunately. (hf brand) I am about to reach 100k so I need to do it soon. Thanks for that thumbnail of the article.
You can do it!
Obliv51 is offline
post #10 of 15 (permalink) Old 05-12-2019, 04:04 PM Thread Starter
Obliv51's Avatar
Actually what I will do is use my ramps. They exactly 8" tall.
You can do it!
Obliv51 is offline
Six Month Report, my Sorento steve807 2016+ Sorento 16 Yesterday 12:00 AM
2011 Sportage Rear Differential Dbep17 3G 2011 - 2016 Sportage 4 11-14-2018 07:14 PM
Sorento Rear AC Metal Line Decided to Stop Holding on to Rubber Line IronmanX 2011 - 2013 (XM) Sorento Forum 10 06-26-2015 07:40 AM
KIA Sorento Rear door speakers cyoung450 2003-2010 Sorento Forum 3 11-16-2011 10:12 PM
