Timing Belt Brand Reccomendation? - Kia Forum
 1Likes
  • 1 Post By ron1004
post #1 of 7 (permalink) Old 05-02-2019, 11:06 PM Thread Starter
Drives: Sorento 2003
Quoted: 9 Post(s)
So I'm working towards replacing the timing belt on my '03 Sorento as well.
Any recommendation on what brand is the best for the belt? I figure since it's a big job, might as well use the best quality belt I can find.
Is genuine the go, or is there an aftermarket brand that is better?
How does this genuine kit look?
https://www.ebay.com.au/itm/GENUINE-...YAAOSwkh9aZWh9
ZacMonkeys is online now
post #2 of 7 (permalink) Old 05-03-2019, 01:53 AM
gee6's Avatar
Quoted: 65 Post(s)
I don't know about a/market brand or what you might have in Australia. Interesting to see a kit of parts sold like that. However, why leave out the necessary crankshaft bolt which MUST be renewed ....... ?
gee6 is offline
post #3 of 7 (permalink) Old 05-03-2019, 04:26 AM
Quoted: 704 Post(s)
Gates makes the OEM belts, and I always look for the Gates kits first, and if unavailable will consider others.
nstoolman1 likes this.
ron1004 is offline
post #4 of 7 (permalink) Old 05-03-2019, 05:04 AM Thread Starter
Quoted: 9 Post(s)
I guess they are assuming that you have already had the crankshaft bolt replaced.
Correct me if I'm wrong but once the crankshaft bolt has been replaced with the new "grey one" then you don't need to replace it again.
post #5 of 7 (permalink) Old 05-03-2019, 08:46 AM
gee6's Avatar
Quoted: 65 Post(s)
New one EVERY time. (Based on the experience of others the 'grey' bolt is not much better than the original).
gee6 is offline
post #6 of 7 (permalink) Old 05-03-2019, 06:45 PM Thread Starter
Quoted: 9 Post(s)
Ah ok, noted. In the videos I have seen regarding replacing the timing belt etc on this engine I have not seen it mentioned that the bolt should be replaced, other than if you find it has the original brass type bolt.
I will order a gates kit and a new bolt as well.
post #7 of 7 (permalink) Old 05-04-2019, 06:43 PM
Drives: Sedona '02
Quoted: 14 Post(s)
Sorento and Sedona same years share same engine that's based on the Mitsubishi v6 engine. The OEM is the Aisin water pump and related belts. You can get the OEM AISIN kit from Rockauto. It comes with Aisin water pump and Mitsuboshi timing belt and other Koyo brand idler pulleys and tensioner.
I bought that one and replaced the timing belt. They fit like gloves. They are very good parts. The timing was perfect with the belt included.
I've heard GATES make good belts, too.
Don't forget to replace the main oil seal at the crank. You should do it when you are already in there.
glycine4 is offline
DIY Timing Belt - WARNING Interference Engine - Service Interval Raven1210 1G (2001-2005) Rio 104 06-04-2016 05:53 PM
Your Steps to install the Crank Sensor dfwtxpatrick 1G/2G (2001-2006) Magentis & Optima 9 11-03-2013 10:53 PM
Timing Belt Rio 2006 Raven1210 Do it Yourself 2 10-16-2013 07:48 AM
Timing Belt Rio 2001 to 2005 Raven1210 Do it Yourself 6 02-19-2012 09:34 PM
How to Replace Timing Belt Raven1210 2G (2006 - 2011) Rio & Rio5 1 05-27-2009 12:16 AM
