Changing Tranny Fluid - Assistance requested - Kia Forum
 3Likes
post #1 of 13 (permalink) Old 04-29-2019, 06:33 PM Thread Starter
Drives: Sorento 2003
Quoted: 9 Post(s)
Im going to change the Tranny fluid in my 03 Sorento. I understand that the manual reccommends a standard drain and fill, but that will only remove about a third of the fluid.
I've read there is another method which involves removing a hose to the radiator which holds transmission fluid and then engaging the transmission to allow the fluid to pump through the system while filling via the dip tube. Effectively re moving about 80-90% of all the old fluid.
Anyone done this on a BL sorento? What tube is it, any reason not to do this vs several drain and fills?
ZacMonkeys is offline
post #2 of 13 (permalink) Old 04-29-2019, 07:12 PM
Quoted: 93 Post(s)
Drain and fills run less of a risk of running the trans pump dry by accident.
Doing what they recommend is not a bad idea. You can, if you have the money,
do several D + F's a few days apart if you want. I use to do them about every 25,000
miles. When I did them I would let the vehicle set for most of the day and would get
an extra qt from the extended drain time. Everyone's MMV. I also dropped the pan at
120,000 miles and checked the inside of the pan and cleaned the screen and magnets
at that time.
nstoolman1 is offline
post #3 of 13 (permalink) Old 04-29-2019, 07:46 PM Thread Starter
Quoted: 9 Post(s)
Thanks for the info.
In that case Ill do 3 or 4 few drain and fills over the course of a few weeks and then drop the pan.
Do you have and advice on dropping the pan and cleaning the screen etc?
post #4 of 13 (permalink) Old 04-29-2019, 08:50 PM
Quoted: 119 Post(s)
I'd not recommend full fluid replacement, do D/F at this AT age and probably many miles by now.
Repeat in 5-10K miles if all goes well with the first D/F.
dubber09 is offline
post #5 of 13 (permalink) Old 04-29-2019, 10:33 PM
rejesterd's Avatar
Quoted: 141 Post(s)
Yep, I agree with the above comments. Do a series of 3-4 drain-and-fills over the span of a few days. Don't overcomplicate it. It's designed to be drained, so do that until the drained fluid is mostly pink. It's a waste of fluid but fluid is cheap.
If the filter is changeable then certainly do that after the last drain. On the newer models, there's no changeable filter but I'm not sure about the '03.
rejesterd is offline
post #6 of 13 (permalink) Old 04-29-2019, 10:57 PM
Quoted: 93 Post(s)
There is a screen in there that can be checked. It is almost a course screen for large particles.
How many miles/KM are one the transmission?
post #7 of 13 (permalink) Old 05-02-2019, 08:43 PM Thread Starter
Quoted: 9 Post(s)
250,000 kms on the transmission. No issues with changing at all, changes smooth as.
Fluid looks about medium-brown on the dip stick, so it has likely been changed at least once before I would say, but probably not for a while.
I think I will just do a single drain and fill initially, drive it for a few weeks and see how to goes, then consider doing another one or two more drain and fills to clean it up a bit further.
I don't think I'll worry about cleaning the screen.
nstoolman1 likes this.
post #8 of 13 (permalink) Old 05-02-2019, 08:44 PM Thread Starter
Quoted: 9 Post(s)
Also just confirming that the 4 speed tranny for the '03 Sorento uses Dex III, correct?
post #9 of 13 (permalink) Old 05-02-2019, 09:58 PM
Quoted: 93 Post(s)
Yes. Unless they have come out with a replacement Dex product. I use to pick it (1 gal jug) up at WalMart under their Tech 2000 brand oils. If you let it drain a long time I think you get 4-5 qts out.
post #10 of 13 (permalink) Old 05-05-2019, 04:08 AM Thread Starter
Quoted: 9 Post(s)
So I did a change and fill, replaced 4 liters with Dex III. All went well. Fluid didn't look too bad, was a bit brown but not as bad as it could have been. Seems to be driving well and changing smoothly.
I think I'll replace another 4 liters in a week or two.
The drain plug bolt was a standard bolt, non-magnetic. I'd like to replace it with a magnetic bolt when I do the next change. I know it's a 14mm head but I'm not sure of the thread size.
Anyone got a link to a magnetic bolt that will fit?
Kia Sorento EX Automatic Transmission Change Richard Fritz 2011 - 2013 (XM) Sorento Forum 8 08-22-2018 04:32 PM
Here is how to change the Sorento EX 2.4L Automatic Transmission Fluid Richard Fritz Do it Yourself 0 07-29-2018 03:54 PM
Mystery part found in tranny fliud drain pan nu2kia 2G (1998 - 2001) Sephia 27 05-16-2009 03:20 PM
Tranny fluid replacement jasn69 1G (1993 - 2002) Sportage 12 06-23-2008 11:22 AM
manual tranny fluid change question? kit352 1G/2G (2001-2006) Magentis & Optima 0 10-08-2007 05:42 PM
