F/R Power Outlets Not Working - Kia Forum
 2Likes
post #1 of 12 (permalink) Old 04-26-2019, 06:30 PM Thread Starter
Drives: 2003 Kia Sorento EX
Quoted: 9 Post(s)
Hi
The front and rear power outlets are not working anymore, there does not seem to be any power going to that fuse. Is there a relay for that fuse that might have gone bad? There was another person here on the site that had the same problem but they didn't say whether or not they fixed the problem.
Any help would be greatly appreciated?
ajdragon is offline
post #2 of 12 (permalink) Old 04-27-2019, 11:52 AM Thread Starter
Quoted: 9 Post(s)
Hi
By any chance does anyone know where this relay is located at? I think its shot, for a split second I had continuity between the 40a BTN1 fuse and the number 9 30a P/SCK fuse.
ajdragon is offline
post #3 of 12 (permalink) Old 05-17-2019, 02:19 PM Thread Starter
Quoted: 9 Post(s)
Hi
I guess no one knows where these relays are, maybe the dealers will know.
ajdragon is offline
post #4 of 12 (permalink) Old 05-17-2019, 04:03 PM
Obliv51's Avatar
Drives: 09 Sorento EX 3.8 RWD
If you post more info about your vehicle maybe someone will be able to help.
You can do it!
Obliv51 is offline
post #5 of 12 (permalink) Old 05-17-2019, 05:30 PM
Quoted: 96 Post(s)
The 03 has 2 fuse boxes. One in the passenger compartment/ DS and the engine compartment /DS near front.
nstoolman1 is offline
post #6 of 12 (permalink) Old 05-18-2019, 01:24 AM Thread Starter
Quoted: 9 Post(s)
Hi
Unfortunately these relays are not in those two spots, I got some hints off of google that they are in one place or another but when I go to search those areas there no where to be found. I think the deals might be the best bet to finding them.
ajdragon is offline
post #7 of 12 (permalink) Old 05-18-2019, 08:51 AM
gee6's Avatar
Quoted: 65 Post(s)
Originally Posted by ajdragon View Post
Hi
Fuses 5 + 6 in passenger compartment panel. Marked 'Cigar (RR)' and 'Cigar (Frt)'. Both 15 amp The "Frt" is for the lighter nest to ashtray and power outlet in front console. "RR" is for outlet in center armrest facing rear seats and the outlet in the luggage compartment. On pre-facelift they only work with ign on. (On facelift they are permanently live).
I have attached a pdf several times. They work ok on my machine, but can't read it as a download from forum. Someone let me know if it is ok or still broken.
gee6 is offline
post #8 of 12 (permalink) Old 05-19-2019, 09:36 AM
Quoted: 96 Post(s)
Works for me
post #9 of 12 (permalink) Old 05-19-2019, 10:33 AM
gee6's Avatar
Quoted: 65 Post(s)
Originally Posted by nstoolman1 View Post
Works for me
That's alright then.
gee6 is offline
post #10 of 12 (permalink) Old 05-19-2019, 10:42 AM
gee6's Avatar
Quoted: 65 Post(s)
Then check Fuse 12 (ACC) which protects the actuation circuit of the socket relays (the circuit going to the relay coil) rather than the actual power itself.
gee6 is offline
Power steering high pressure hoses removal issue, both high and lower hoses. Learning 2G (1998 - 2001) Sephia 2 05-29-2018 07:07 PM
Power outlets not working ScarbSXL15 Kia Carnival & Sedona 2015+ 2 12-22-2017 10:19 AM
A/C, power windows and wipers quit working NeilM Kia Sportage Forum 3 09-09-2008 08:04 AM
