2004 Sorento Finding cause of smoke or steam - Kia Forum
 4Likes
post #1 of 17 (permalink) Old 11-16-2017, 12:10 PM Thread Starter
bealert's Avatar
Drives: Kia Sorento 2004
Exclamation 2004 Sorento Finding cause of smoke or steam
Hi folks--A few weeks ago had to replace tie rods and from what I've read it involves removing the steering column. A week later stopped at light I saw a puff of smoke coming from hood at front passenger- Pulled off road and it stopped when I shut off - I have a great mechanic so went right back and he looked all over the engine but didn't find anything wrong.
2 weeks later it happened again yesterday- I was parking and shutting off when the smoke appeared- It stopped immediately once parked. Went back again and now he wants to do a diagnostic etc. tomorrow
Yesterday a neighbor checked the area for me and found a hose connected from the power steering fluid to a box of sorts was greasy but car shut off so not dripping. He thinks it could be dripping now and then onto the alternator or exhaust which is hot and creates a puff of smoke...Hopefully it's a simple fix.
My question is--- did mechanic have to disassemble this hose and perhaps didn't secure it properly? The only thing keeping it together seems to be a squeeze clamp- could it be as simple as tightening that??
Thanks so much for help- I'm scheduled to go to mechanic tomorrow - and can't afford 85/hr just to find what he would have to warranty....
bealert is offline
post #2 of 17 (permalink) Old 11-16-2017, 06:46 PM
Quoted: 96 Post(s)
My guess is the valve cover gasket. They get a slow weeping leak and drip off the back side on to the exhaust manifold. Pull the inner wheel liner and you will see inside. It also could be used to look for the PS leak if that is going on.
nstoolman1 is offline
post #3 of 17 (permalink) Old 11-16-2017, 10:00 PM
Drives: kia sorento ex 05
Is that slow weep from the valve cover gasket fixable? I had the gasket changed on my 2005 3.5lt Ex 5sp auto & was good for a few months but now seems to be back again. Is it possible that it happens more when oil is full rather than 3/4 on the dip stick?
Sorry to hijack your thread bealert
andreko is offline
post #4 of 17 (permalink) Old 11-17-2017, 12:51 AM
Quoted: 96 Post(s)
Code:
It is fixable if the right gasket and sealer is used.
Also if a person is going in that deep they should replace everything that is questionable in "Time in use".
post #5 of 17 (permalink) Old 11-17-2017, 11:36 AM Thread Starter
bealert's Avatar
Thanks for input - My main question was - what I needed to know :did the mechanic have to pull the power steering fluid unit and hose when he replaced the tie rods ??
bealert is offline
post #6 of 17 (permalink) Old 11-17-2017, 11:39 AM Thread Starter
bealert's Avatar
Thanks-- guess the gasket is possible but as far as location of the smoke - or steam -it comes from FRONT right side of hood- which I think is closer to the power steering fluid hose. Can't seem to get an answer if mechanic had to remove power steering unit and hose during tie rods replacEments- Do you know??
bealert is offline
post #7 of 17 (permalink) Old 11-17-2017, 12:07 PM
Drives: 2017 Kia Forte
Quoted: 9 Post(s)
Have you tried just leaving it running when you see the smoke so you can try to pinpoint it? I'd suspect that power steering connection since your neighbor said it was greasy. I'm new to Kia, so don't know if your mechanic had to take it loose or not. Sorry about that.
Keep smiling, no matter what. It makes people wonder what you've been up to!
chuzz is offline
post #8 of 17 (permalink) Old 11-17-2017, 12:19 PM Thread Starter
bealert's Avatar
Thanks Chuzz-- It happens so seldom hadn't thought of that because I kinda freak when I see it. From talking with mechanic a few minutes ago he said no - didn't have to remove the p-steering unit-- but agrees it shouldn't look greasy so it could drip periodically on the exhaust - The smoke comes from that area though [front right passenger side under hood] it disappears as soon as the leak is burnt up I guess....
Won't be going to mechanic today because he said it isn't that serious and can wait until after Thxgiving. And my son is taking me to Tahoe for my birthday too on Monday....Will come back here after seeing mechanic with the answer just in case it helps someone else with the same issue...
HAPPY THANKSGIVING -
bealert is offline
post #9 of 17 (permalink) Old 11-29-2017, 10:45 AM
Quoted: 9 Post(s)
I hope you get it figured out. Let us know what happens and I hope you have a great time in Tahoe. I've always wanted to go there.
bealert likes this.
chuzz is offline
post #10 of 17 (permalink) Old 12-13-2017, 02:02 PM Thread Starter
bealert's Avatar
Question 2004 Sorento Power steering fluid light
PLEASE SEE UPDATE BELOW --new discovery.....
it is the HEAD GASKET
2004 SORENTO 4X4 LX
Thought the dash alert was for window wash fluid because I checked the manual-- so figured no big deal..would fill it eventually -- the periodic rain helped me procrastinate............[go ahead laugh] .
UNTIL the light would not go off -- I feel like a bit stupid now....... figured it out that the icons were similar for power steering fluid so immediately got fluid-
A friend poured it because it was at the low line ---but went a bit lower than the High line because he said the fluid would expand...and possibly overflow damaging the pump.... OK what do I know...
Took it for drive -- light goes out when I brake but otherwise it stays on and will not go off - Car runs and turns great- If I can get friend to get the fluid up to the High line would it expand and overflow?? Is light staying on because it's not at the High line ---- OR How else to get the light to go out??
Thanks for input - even though everyone is busy with the coming holidays would appreciate opinions.
Cheers
Katy
bealert is offline
Sorento 2004 cutting out black smoke sapper 2003-2010 Sorento Forum 2 08-12-2016 07:31 AM
2004 Sorento EX Fuse Box Fire KursedEX 2003-2010 Sorento Forum 7 11-18-2015 08:21 AM
2011 Kia Sorento Power loss, rattling, smoke Plumber Dom 2011 - 2013 (XM) Sorento Forum 2 06-12-2015 08:02 AM
Need FCC Id for 2004 Sorento Remote Entry Fob pdotek 2003-2010 Sorento Forum 3 03-22-2007 03:22 PM
