Rail pressure engine shut down - Page 2 - Kia Forum
 2Likes
post #11 of 13 (permalink) Old 09-04-2017, 03:33 PM
gee6's Avatar
Quoted: 65 Post(s)
Only a single (dual-function) pump on the Sorento - mechanically driven off the timing gear. The common rail pressure is very high == 1600 BAR or thereabouts (You don't mess with it). Pressure sensor on top of rail and a release valve on the end to dump excess back into the fuel system.
@yachtmustang = Do you by any chance have a powerbox of any type fitted? They attach where the rail pressure sensor fits and modify the readings back to the ecu. So a failure there might cause the issue you have.
gee6 is offline
post #12 of 13 (permalink) Old 09-05-2017, 01:42 AM
aquanaut20's Avatar
Quoted: 251 Post(s)
If the vehicle does not have a lift pump, it relies on suction to draw fuel, so either you have a leak between the pump and fuel cell (breaking suction/air), or a fuel line is collapsing internally and cutting flow (you wont see this externally)..
... Philip
aquanaut20 is offline
post #13 of 13 (permalink) Old 09-05-2017, 05:28 AM Thread Starter
Drives: Sorento 2007
Hi. Sounds good for the leak-back test. That was my next port of call. I figured if an injector was getting stuck or leaking that could cause a dramatic fall in the rail pressure and trigger the failure. And BTW I don't have a powerbox on rail bar so injector is probably best place for next investigation.
Thx for the help
yachtmustang is offline
P0091 Fuel Pressure Regulator 1 Control Circuit Low ryan000 2011 - 2013 (XM) Sorento Forum 6 03-09-2018 07:25 PM
Check engine - Low Oil pressure lights Leinie Kia Carnival & Sedona 2006+ 8 12-31-2015 05:01 PM
exhaust smoke ??? mybrosride 2G (1998 - 2001) Sephia 63 12-03-2008 04:00 PM
Clunking noise and engine shut down FSALIFU 2003-2010 Sorento Forum 2 10-25-2008 03:48 PM
03 Engine Cuts Out jcb 1G (2001-2005) Rio 3 07-09-2006 11:29 PM
