Flickering Battery/charge and stop light - Kia Forum
post #1 of 2 (permalink) Old 04-20-2017, 10:49 AM Thread Starter
Spencernj's Avatar
Drives: Kia Ceed, MGTF, Various Jeeps new and old, FIAT 500
Yesterday, I a strange problem started to occur. Very intermittently the charge light (and stop/brake) light flicker on my 2009 EX 2.5. (103,000 miles but well maintained since I got it, but no comment on the main Dealer$ efforts, and in v good condition)
I have checked the obvious (belt), connectors, battery (indicator green). Put a voltmeter on the battery stopped and running (both readings correct and stable at different revs). Turned on everything electrical (voltage stable @ 14.2 volts drops to 14.09 when everything is turned on full, but measured inside not at the battery as didn't have a helper). I may be imagining things but when it flickers I may also have a momentary lack of power (like a singe misfire on a petrol). Earth straps seem fine, and have swapped the MAIN relay with one of the accessory ones. (P/WIN). It looks like one of those intermittent faults that I may have to let get worse before I can find the cause unless anyone has experienced anything similar.
Spencernj is offline
post #2 of 2 (permalink) Old 04-20-2017, 06:31 PM
Drives: '96 Camry v6 XLE, '00 Camry LE
Quoted: 125 Post(s)
Greetings,
How old is the Battery? Has it been load tested?
Original alternator? Any noise from alternator, or accessory tensioner / idler pulley, if equipped? Has it been load tested?
Edit: Have -all- fuses and relays been checked in the engine and passenger cabin compartments for condition / voltage / to ensure they are seated firmly in sockets?
Any aftermarket (lighting, audio, starting, etc.) accessories installed? If so, have they been disconnected / wiring reset to factory stock to see if the issue lessens / goes away?
^^ Above, with cleaning battery terminals & primary ground points would be where I would start, if here.
Regards,
GottaCruise
OBD-II Codes:
Last edited by GottaCruise; 04-20-2017 at 06:35 PM. Reason: Check all fuses/relays for condition as a primary diagnostic step..
GottaCruise is offline
Fog Light stop working after ... Spyde 3G 2011 - 2016 Sportage 8 10-29-2017 11:18 AM
2007 Optima Dome Light Problem lifterguy 3G (2006.5+) Magentis & Optima 0 10-10-2017 05:04 PM
Stop light bar on 5th door trunk (leak) tcrbio 3G (2012 - 2017) Rio 6 02-08-2017 06:08 AM
Rough idle at stop light charlieg 1G (2001-2005) Rio 13 03-25-2010 08:01 AM
Light bulbs for 06 Sedona Repsolal Kia Carnival & Sedona 2006+ 2 12-17-2008 10:44 AM
