Kia Sorento - Help - Kia Forum
 1Likes
  • 1 Post By gee6
post #1 of 4 (permalink) Old 08-03-2016, 12:11 AM Thread Starter
Drives: Kia Sorento
Kia Sorento - Help
https: //i.imgsafe.org/ 17b370b180.jpg
This warning light lights up from time to time when driving. I'm not sure what it means. The mechanic said it had something to do with diesel filters (they were filled up). When the light is lit, the car accelerates very poorly and slowly. The light still lights up after the car was taken to a mechanic.
Also, sometimes it just won't start up. I have to try starting it up multiple times. Any help would be appreciated.
(sorry if I made any grammatical mistakes, English is my second language)
blaze8x is offline
post #2 of 4 (permalink) Old 08-03-2016, 12:23 PM
Quoted: 95 Post(s)
The forum will need more information on the car. You mentioned diesel. What engine size, transmission, year and your pic did not come through.
oh and to the forum.
And I am zero help with diesels.
nstoolman1 is offline
post #3 of 4 (permalink) Old 08-03-2016, 01:52 PM
gee6's Avatar
Quoted: 65 Post(s)
That's the 'water contam' sensor light fitted to the bottom of the diesel fuel filter. ie water from (bad) diesel has collected in the bottom of the filter and reached the sensor level (in theory). You can replace the fuel filter alone, re-using the water sensor - but make sure you get a filter that matches the sensor, there are different versions with different fitments. If you get a kit from Kia then you should get both - the sensor costs more than the filter! Kia sell both to ensure you don't have a mis-match. Several years ago, Kia switched from Bosch to Mahle filters as oem part as there were 'issues with the oem Bosch' (according to my source). If you just buy a filter, you can run with the supplied cap in place without the sensor. Just make sure the harness connector is secured out of the way and covered. Otherwise, sounds like a possible connection problem.
A bad sensor will normally just cause the light to flash intermittently (I had one that did that). Your issue sounds more than that. If a new filter does not fix, you may have issues with injector damage and/or pump.
If your manual says 'change every 40k miles (or equivalent)' make that every 20k miles or 2 years (or more frequently). They changed the service schedule when they changed oem supplier.
Here endeth todays lesson
nstoolman1 likes this.
gee6 is offline
post #4 of 4 (permalink) Old 08-04-2016, 12:07 AM Thread Starter
Drives: Kia Sorento
@nstoolman1
To see the link, just remove the two spaces from it. Because I'm a new user I'm not allowed to post links.
@gee6
Thank you for the information.
blaze8x is offline
Towing 5000 lbs with the Sorento - Myths and facts rocky_baker 2016+ Sorento 20 08-27-2018 05:12 PM
'16 Sorento vs '17 CX-9 jenwest99 2016+ Sorento 22 05-01-2016 12:24 PM
2017 Sorento Info mjonis 2016+ Sorento 11 03-10-2016 03:44 PM
Kia Sorento Crankshaft Pulley Bolt Shawn 2003-2010 Sorento Forum 17 05-20-2011 09:07 AM
Moved from Sedan car to SORENTO and the first impression ! Zaher 2003-2010 Sorento Forum 3 11-04-2007 11:49 AM
