Just bought (new to me) 2005 Kia Optima, What maintenance i should do? (112k) - Kia Forum
post #1 of 7 (permalink) Old 12-13-2008, 03:28 AM Thread Starter
Drives: 2005 Kia Optima LX
Greetings fellow kia owners.
i just bought a (new to me) 2005 Kia Optima (4cyl), with 112k miles.. drives good...
but it was missing the owners manual, and i know nothing about KIAs before i bought it, it just drove nice, and i was sold on it.. (plus i got it at a good price).
i was wonder what should i have done?
ive been reading the other post.. should i go ahead and install a new timing belt?
what other things should i look out for?
anyone have a maintenance list?
Thanks again..
i love this car, and i hope to post upgrades here soon..
timtim2008 is offline
post #2 of 7 (permalink) Old 12-13-2008, 07:11 AM
Drives: 2017 Kia Sorento LX AWD
Quoted: 42 Post(s)
Very nice looking car. Go here Kia Global Information System (KGIS) and sign up for a free account. You can get all sorts of info here including an owners manual.
brsexton is offline
post #3 of 7 (permalink) Old 12-14-2008, 06:07 PM
get ready to drop 6-700 on a timing belt asap if you dont have any receipts for it being done.
kit352 is offline
post #4 of 7 (permalink) Old 12-14-2008, 06:36 PM Thread Starter
so is the timing belt the only thing i should be worried about?
post #5 of 7 (permalink) Old 12-14-2008, 08:55 PM
its pretty much the only preventive thing to watch out for. it has and will cause problems if not addressed.
kit352 is offline
post #6 of 7 (permalink) Old 12-14-2008, 11:31 PM
Raven1210's Avatar
Drives: 1999 Acura Integra
Gallery: 1
heres a Maintenance Schedule if u dont have one
Months Kilometres Maintenance Type
4 months 6 000 km Maintenance #1
8 months 16 000 km Maintenance #2
12 months 24 000 km Maintenance #1
16 months 32 000 km Maintenance #3
20 months 40 000 km Maintenance #1
24 months 48 000 km Maintenance #2
28 months 56 000 km Maintenance #1
32 months 64 000 km Maintenance #3
36 months 72 000 km Maintenance #1
40 months 80 000 km Maintenance #2
44 months 88 000 km Maintenance #1
48 months 96 000 km Maintenance #3
52 months 104 000 km Maintenance #1
56 months 112 000 km Maintenance #2
60 months 120 000 km Maintenance #1
64 months 128 000 km Maintenance #3
68 months 136 000 km Maintenance #1
72 months 144 000 km Maintenance #2
76 months 152 000 km Maintenance #1
80 months 160 000 km Maintenance #3
84 months 168 000 km Maintenance #1
88 months 176 000 km Maintenance #2
92 months 184 000 km Maintenance #1
96 months 192 000 km Maintenance #3
100 months 200 000 km Maintenance #1
104 months 208 000 km Maintenance #2
108 months 216 000 km Maintenance #1
112 months 224 000 km Maintenance #3
116 months 232 000 km Maintenance #1
120 months 240 000 km Maintenance #2
124 months 248 000 km Maintenance #1
128 months 256 000 km Maintenance #3
MAINTENANCE #1
MAINTENANCE #1 INCLUDES:
Replace engine oil and filter
Check fluid levels (pwr. strg., brake/clutch, coolant, washer)
Check tire condition and pressure (including spare)
Check exterior & interior lights for proper operation
Check windshield washer/wiper function
Check horn function
Check handbrake function/freeplay
Lubricate all latches, hinges and locks
* = if equipped
See "Model-Specific Maintenance"
^Top
MAINTENANCE #2
MAINTENANCE #2 INCLUDES:
Check horn function
Check engine coolant specific gravity
Check engine air filter; knock out dirt/bugs, replace as req'd
Remove wheels and brake drums, check pad/shoe thickness; inspect calipers, cylinders and shoes for proper function, leaks or damage; adjust rear brakes as required.
Rotate tires
Visually check underbody fasteners for condition & integrity
Check brake/clutch pedal freeplay
Check steering wheel components for proper operation
Check CV boots/tie rods/ball joint boots (visual inspection)
Check all seat belts and anchor integrity
Check exhaust sys. for leaks, mountings, brackets; heat shield
Check transfer case oil level & condition, fill as required
Check front & rear differential fluid, fill as required*
Check man. transaxle oil level & condition, fill as required*
Check auto transaxle fluid level & condition, fill as required*
Lubricate driveshaft u-joints (early Sportage only)
Road test vehicle
* = if equipped
^Top
MAINTENANCE #3
MAINTENANCE #3 INCLUDES:
Check horn function
Check coolant specific gravity
Inspect, deglaze, clean, adjust & lubricate brake components
Rotate tires
Check transfer case oil level & condition, fill as required*
Check idle speed
Inspect power steering lines & hoses (visual)
Check A/C compressor operation and performance*
Check brake line fittings, bleeder screws, booster for damage, looseness, leaks
Road test vehicle
* = if equipped
^Top
KIA MODEL-SPECIFIC MAINTENANCE
In addition to the KIA Basic Scheduled Maintenance, certain KIA Models will require the following maintenance services:
ALL MODELS
(Every 36,000 km or 18 months)
Manual transaxle service (except Sportage)
Automatic transaxle service (except Magentis)
Check drive belt condition & tension
Inspect front ball joints
ALL MODELS
(Every 48,000 km or 24 months)
Replace engine coolant
Replace engine air filter
Inspect fuel lines & connections
Inspect ignition wires
Replace spark plugs (except Platinum)
ALL MODELS
(Every 60,000 km or 30 months)
Replace brake/clutch fluid
Inspect EVAP canister & vapour lines
ALL MODELS
(Every 72,000 km or 36 months)
Replace fuel filter
Inspect PVC system/hoses for integrity
ALL MODELS
(Every 96,000 km or 48 months)
Replace spark plugs (Except Platinum)
ALL MODELS
(Every 102,000 km)
Replace timing belt
SPECTRA
(Every 12,000 km or 6 months)
Replace HVAC air quality filter (if equipped)
MAGENTIS
SPORTAGE
Transfer case, differential & manual transaxle service
Transfer case & differential service (auto. trans. model)
SORENTO
Raven1210 is offline
post #7 of 7 (permalink) Old 12-28-2008, 12:14 PM Thread Starter
thanks guys
just did timing belt, ac belt, and drive belt
2005 optima windshield on 2006.5 optima possible? Michael Pedzimaz 3G (2006.5+) Magentis & Optima 3 02-25-2016 11:18 AM
basic tuneup info needed InlawsKia 2G (1998 - 2001) Sephia 5 10-13-2006 12:04 PM
Maintenance Schedule Raven1210 2G (2006 - 2011) Rio & Rio5 0 10-13-2006 12:58 AM
Maintenance Schedule Raven1210 1G (2001-2005) Rio 0 10-13-2006 12:56 AM
02 Rio Scheduled Maintenance dyerea 1G (2001-2005) Rio 1 10-06-2006 12:48 AM
