03 Rio Cinco problems and a couple solutions - Kia Forum
post #1 of 7 (permalink) Old 04-26-2018, 06:05 PM Thread Starter
Drives: 2003 Rio Cinco
Hi. I'm new to this forum. This is my 1st post. I'll do my best to make it short.
I picked up my 03 Rio Cinco 5 speed, 157K miles, one-owner car (retirees from Maryland to SC) almost two months ago after my 99 GMC truck started shearing teeth off the flex plate. My wife has a '15 soul, so when I saw the Rio I jumped on it.
The first week I had it was awesome. Its not the fastest of cars, but with only 1.6L....meh. Literally, day 8, I picked my son up from school. About a mile after we left his school, I'm waiting at a red light and it just starts shaking, running rough. I gave it some gas and it seemed to correct itself. It was fine the rest of the way home. The next morning it did it again, twice, then a few times on the way home. Waited an hour and let it cool off. Found a couple spark plugs that had some gnarly build up. Put those same spark plugs back in just to see....it started up just fine and ran great til I got to the parts store for some new economy plugs and a bottle of gas treatment. The gage was showing half a tank so I just poured it on in.
No problems til the next afternoon. The shaking thing happened a couple more times and then it didnt stop. Of course the engine light came on. I've seen this before....ignition coils. Luckily I was only a couple miles from home at this point so I just chugged on.
Once I got home, it gave me P0300(random multiple misfired), P0302(cyl 2 misfire), & P0303(cyl 3 misfire). I found a reman coil set online, shipped to my door for about $40. While I waited for my part to arrive, I did some research about my Rio. Eventually came across this forum. I read most of every thread and put together some useful stuff in my head that really helped me think through what was to come.
The "new" coil packs came. Got them on and took it for a test drive. It ran great. It had some pep to it....for about 15 minutes. Chugged back home. It gave me a O2 sensor code (bank 1 sensor 2) this time. I took out the O2 sensor, cleaned it and put it back. Seemed to do the trick...for a few hours. I found a new sensor online relatively cheap. I came back to the forum and re-read some more. After a new O2 sensor and another failed test drive, I got cylinder 2&3 misfire again. My neighbor is the electrical/HVAC tech where he works, so I got him to come over and check out the electrical system. While he was checking the ignition, his timing light was strobing. He looked at me puzzled. I told him about the wasted spark thread. After thinking for a few minutes he understood why. Each of the 2 leads is sending 5V to its corresponding coil, so both spark plugs fire simultaneously. Those connectors lead back to the fuse block, then to the ECU, so the ignition is directly fired by the ECU. The only thing between is a fuse and a relay. Hopefully that will help someone.
That was not the problem with my Rio, but it is good info.
Took the time to clean the injectors, replace the fuel filter, fuel line flush, pressure test, ran down the fuel lines to check for any leaks, beat my head against the wall, did some more research. I came across a video where a guy had crumbling ignition connectors. They literally fell apart when he squeezed them to pull them from the coil packs. I realized that mine were new....hmmmm.
I went and unwrapped the nicely taped wires back to the butt splices. The butt connectors for lead 2/3 were a couple gobs of melted plastic. Lead 1/4 were a couple of beautiful blue butt connectors with the usual "AWG" printed down the length. That "Aha" moment....Someone did a tune up on this car before I got it and wired the connector backwards ( 1 positive wire, 1 negative wire).
That seems to be the issue. Ive had a couple O2 codes pop up that didnt seem to effect driving. I disconnected the battery for a minute both times and the codes cleared. And had to clean the TPS. It had a bad dive shifting into 2nd. I did it the cheap-o way. Propped open the throttle with some blue shop rags and sprayed carb cleaner. I let it air out over night. While I had the air cleaner off, I hit the MAF with some cleaner. I'll probably get an other TPS in a couple weeks. I need to put some money back in the bank first. Hope this helps someone. Thanx
Mychal is offline
post #2 of 7 (permalink) Old 04-26-2018, 06:48 PM
Quoted: 704 Post(s)
Welcome.
Make sure you install a timing belt kit if you don't have records when it was last done - failed TB is the most common engine killer on these models.
ron1004 is offline
post #3 of 7 (permalink) Old 04-26-2018, 07:21 PM
Drives: 2014 Hyundai Veloster Turbo / 2001 Kia Rio
Quoted: 19 Post(s)
Nice find!
And what ^^^ said about the belt. Rockauto has a whole kit with the belt, pump, and pulleys all by Aisin. While you’re at it get the cam and crank seals at the same time.
rpw00mirage is offline
post #4 of 7 (permalink) Old 04-26-2018, 08:13 PM Thread Starter
Yeah, I keep reading about timing belt failure. Definitely in the plans. Thanx for the tip on the kit. Anything screwy to watch out for? I'm assuming by the layout that I have to support the motor and take the motor mount loose to be able to get to bolts/back bolts out?
Mychal is offline
post #5 of 7 (permalink) Old 04-26-2018, 08:18 PM Thread Starter
My Rio Cinco
Mychal is offline
post #6 of 7 (permalink) Old 04-27-2018, 08:27 AM
Quoted: 19 Post(s)
you should support the motor with a jack when you do it. make sure you can get the crank pulley bolt loose before disassembling anything.
post #7 of 7 (permalink) Old 05-10-2018, 07:45 PM
Drives: 02 Rio Cinco / 02 Civic Ex
Quoted: 4 Post(s)
One suggestion i use when changing the timing belt on my 02 RIO (has 2 cam gears). I put a small spot of white paint on the old belt in three places (before removing), and three more spots directly in line on the side of each cam gear and on the bottom side of the crank gear. Put the white paint spots in line with the belt's tooth and in line with its tooth valley on each gear.
Then after removing the old belt lay it directly on top in line with the new timing belt and transfer those white spots to the same tooth location on the new belt. Critically important that you double check to make sure the white spots on the new belt are in the same tooth location as on the old belt. This insures that the new belt isn't accidently 1 tooth off on one of the gears which throws off the timing and all your work for naught.
The other problem with a two cam KIA Rio engine is trying as best you can to get the new belt on/over all three gears and at the same time preventing one or both of the cam gears from moving while attempting to install the new belt. When one installs a new timing belt it almost seems to short. I actually removed the idler pulley and still it was a tight fit forcing the new belt over the two cam gears. The white spots ensure correct alignment of the two white spots on the belt with the two white spots on the cam gears. Then i pried the idler pulley back in position and lucky me the idler pulley bolt hole aligned with the hole in the engine block so the threaded bolt took hold into the threaded engine block hole on the first try. In hind site i may not have needed to remove the idler pulley if i had aligned the new belt over the two cams first and then forced the new belt onto the crank gear making sure all three white spots on the belt, two cam gears and crank gear were aligned directly across from one another to insure correct timing.
Maybe, someone else has other suggestions ... although that tool that secures the two cams together that is suppose to prevent either cam from moving during belt installation isn't guaranteed to prevent the cams from moving when your trying to force the belt onto both cams (from what i've heard).
02KIACinco is offline
04 kia rio Cinco acceleration problems and smell Bkautocare 1G (2001-2005) Rio 4 07-19-2017 05:18 PM
2011 Sedona EX with ALLLLLLLL the problems centrefrenchie Kia Carnival & Sedona 2006+ 3 01-23-2017 05:32 PM
Semi-common problems on base Sorento (w/manual transmission) mrand 2011 - 2013 (XM) Sorento Forum 4 08-26-2015 04:24 PM
Kia Spectra 2006 - Couple of Problems bmkozlowski Kia Cerato, Shuma & Spectra Forum 5 08-22-2014 07:59 AM
96 sephia problems please help jthompson85 Kia Sephia Forum 0 01-02-2009 07:02 PM
