My Kia Rio Problems Summary - Page 3 - Kia Forum
post #21 of 27 (permalink) Old 08-11-2015, 09:18 AM Thread Starter
Originally Posted by derekagraham View Post
If the timing is off would it cover and go
According to my mechanics words, this car is a dual camshaft so 1 controls intake the other out(exhaust), so when one is close the other should be open. there are two marks in each cam so when cam 1 is on mark A , cam 2 should be on Mark B. In my case when cam 1 was on mark A, cam 2 also was on Mark A, so there wasn't a complete open/close valve cycle. Meaning that before the intake valve was completly closed the exhasut was already opening, that causes loss of compression and therefore power and all kinds of silly behaviour from the enginge that on my case was 75% of the problem, another 15% was the crank sensor eventhough was new had to replaced with a used "working" one. The other 10% Im still trying to figure out, and yes you will need a good mechanic to tackle this.
Michael Oaks is offline
post #22 of 27 (permalink) Old 11-30-2015, 10:23 PM Thread Starter
After more than three months my issues persisted, to be honest the last thing I've tried was changing the fuel pump and it didnt solve the problem. after that I got tired of throwing rocks at the moon, but now I want to fixed it, to see If Im able to sell it or trade it for something else.
post #23 of 27 (permalink) Old 12-01-2015, 05:20 AM
Drives: 2014 Kia Rio5 EX
Quoted: 38 Post(s)
Man that sucks. Sorry to hear.
Sent from AutoGuide.com Free App
Jasper18 is offline
post #24 of 27 (permalink) Old 12-01-2015, 08:16 AM Thread Starter
Before venturing into replacing more electrical components I'm going to try Kevsters route and replace the Intake Gasket and tested for a week or so..
post #25 of 27 (permalink) Old 12-03-2015, 12:37 AM
Sorry to hear you have had so many problems. Your P0325 code reminded me of when I received that code recently. The 1st gen Rios were horrible when it comes to engine/body grounds. There is really only two from the negative battery cable and the one that connects to the body does so near the battery tray, which is not the greatest place to put a ground due to corrosion.
Have you tried running a redundant ground wires to both the body and the engine? This fixed my P0325 and a few other issues I was seeing.
Mordecai77 is offline
post #26 of 27 (permalink) Old 12-03-2015, 06:34 AM Thread Starter
No, actually the only ground I've checked was the one on the passenger side near the timing belt cover, but I did took out the injectors wire harness and the throthle body harness and physically check each wire for splits and did a continuity test at each end for each wire... I will check into that ground you mention, one thing though this car seems to trigger many false alarm codes when it fails.
post #27 of 27 (permalink) Old 12-03-2015, 07:25 AM Thread Starter
Actually I did replace the knock sensor with an original part, and after that it has only come on twice when you keep trying to run the car with other codes on. Keep in mind that the car will run ok for about 45 minutes or 45 miles then P1166, P1529 and P0741 If keep on going with these codes on then the car would shut down and register other random codes like knock sensors and misfires...
2011 Sedona EX with ALLLLLLLL the problems centrefrenchie Kia Carnival & Sedona 2006+ 3 01-23-2017 05:32 PM
Semi-common problems on base Sorento (w/manual transmission) mrand 2011 - 2013 (XM) Sorento Forum 4 08-26-2015 04:24 PM
2007 Sorento Problems KoYo 2003-2010 Sorento Forum 8 03-21-2009 10:12 AM
Well-known problems catie 1G (1993 - 1997) Sephia 8 03-17-2008 01:09 PM
A/C problems, seat problems, headlight ?.. 02kiasedonaowner Kia Carnival & Sedona Forum 1 03-28-2007 09:02 AM
