Clogged Exhaust/Catalytic Converter? - Kia Forum
LinkBack Thread Tools
Old 08-04-2010, 05:47 PM Thread Starter
Drives: 2000 Sportage 4x4, 1997 & 1994 Honda Civics
Quoted: 4 Post(s)
Exclamation Help!Clogged Exhaust/Catalytic Converter?
How do I know if my cat or exhaust are clogged?
With the car being tuned up, all I can think of is exhaust issues. Is there a way to check? Also, would adding a new fan clutch cause sluggish performance? It happens with or w/o the AC on.
I recently replaced my exhaust manifold and upper Oxygen Sensor (use Bosch, don't try the universal Replacement brand). I also replaced the fan clutch. I'm now experiencing some sluggish performance on acceleration and some occasional, slightly high idling.
I'm wondering how to check if I have a partially clogged exhaust or lower cat (upper cat was replaced last fall as it had completely burnt out leading me to believe the lower is partially clogged)?
A little maintenance history:
  • New plugs
  • Air Filter
  • Cleaned IAC and MAF the other day
  • New plug wires
  • New fuel filter last month
  • New fan clutch
  • New PCV valve last fall
  • New upper O2 sensor
  • New upper catalytic converter
  • Regular oil and manual trany oil changes
  • had a smoke test last fall to check for vacuum leaks (none)
SLCSportage is offline
Old 02-09-2013, 05:10 PM
Drives: 06 mitsubishi eclipce gt-se v6 106k miles , 00 sportage base 72,802 miles 2wd... purple...
Gallery: 6
i have the same Q, can anyone help.
zkdawg is offline
Old 02-09-2013, 05:43 PM
aquanaut20's Avatar
Quoted: 251 Post(s)
Remove the B1S1, install a nipple and connect a low pressure gauge, (vacuum gauge will do), No more than 2.5psi @2500rpm...Philip
Name:	vacuum gauge.jpg
aquanaut20 is offline
Old 02-09-2013, 05:48 PM
Gallery: 6
what about psi at the sensor under the pre cat?
wouldn't that be where i want to check for a clogged cat?
zkdawg is offline
Old 02-09-2013, 06:37 PM
aquanaut20's Avatar
Quoted: 251 Post(s)
The B1S1 is the O2 sensor directly after/on the exhaust manifold, upstream of ALL CATs... Philip
Old 02-09-2013, 08:27 PM
Gallery: 6
i know, thats why i said wouldnt u test the one AFTER the CAT to see how much is making it through?
zkdawg is offline
Old 02-09-2013, 10:45 PM
aquanaut20's Avatar
Quoted: 251 Post(s)
My test is SOP, if you know better, why ask?..... Philip
Old 03-21-2019, 11:00 AM
Drives: 2008 Kia Rio LX
the exhaust system post cat should not have any restrictions .. its a 2 inch pipe! useless test.
Fireater1968 is offline
Old 05-20-2019, 12:07 AM
Drives: 2001 Sportage, FE DOHC Engine 5 SPD Manual Petrol
Quoted: 10 Post(s)
The cat on my 2001 sportage is about the size of peanut butter jar. There's an upstream, a downstream, and then a muffler nothing else. It's the Federal one that cost the most. Downstream would signify "after"
ZorgEntity is offline
Old 05-20-2019, 12:20 AM
Quoted: 10 Post(s)
I know what he meant. Test the pressure on both. If the downstream has less pressure than the upstream it has a clog.
Please Help! Can't identify the problem! Air/Gas Issues, catalytic converter. Izoliner Kia Carens & Rondo Forum 2 06-07-2016 12:16 PM
Pre Heater Or Catalytic Converter ZorgEntity 1G (1993 - 2002) Sportage 5 09-24-2015 11:57 PM
2000 Sportage Catalytic converter mig65 1G (1993 - 2002) Sportage 10 12-07-2013 09:56 AM
catalytic converter trouble patricksharon 1G (1993 - 2002) Sportage 1 03-26-2009 03:12 PM
'02 Kia - misfire and then catalytic converter probs liquidleaf 1G (1993 - 2002) Sportage 0 08-22-2007 06:51 PM
