cold start problem 2001 sportage - Kia Forum
post #1 of 2 (permalink) Old 07-10-2009, 07:37 PM Thread Starter
Drives: 2001 Auto Sportage 4WD, 2008 Falcon XR6,
I have a 2001 sportage twin cam which has a problem when cold, the engine is sluggish until it reaches operating temperature, the ecu light is not on and I have had a scanner check for fault codes but none are present.
It may be a coincidence but the problem only started after I serviced the transmission. I used the wrong grade of trans oil but corrected this later by using dexron 2.
If anyone has had the same problem or can help I would appreciate it.
P.S. I am in Australia and the temperature at the moment is around 2 degrees in the morning. My car is in a garage at night.
reginald is offline
post #2 of 2 (permalink) Old 07-10-2009, 10:06 PM
PLP
PLP's Avatar
Quoted: 330 Post(s)
eginald,
first, add all this info to your profile - I mean location, car...
Next, could you say how many miles/kms did you put on it? What other things were done recently - such as spark plugs, cables, oil, air filter...
What oil grade it was? Was it thicker than it should have?
Humidity - is it humid in the morning?
Temperature - I believe since in Australia you are talking about C, not F
So, when this problem occurs, do you feel it has power? Do you feel any misfire? Does it shift fine (auto or manual?)?
If it was not done - check spark plugs. When cold they need more energy to ignite fuel. Also, inspect cables as well as coils.
Then, can you say it is a problem of too much fuel, or too much air?
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
2001 rio automatic cranks, wont start wierd myposhak 1G (2001-2005) Rio 2 10-06-2009 01:20 PM
'01 Sportage no start saabfan 1G (1993 - 2002) Sportage 14 10-02-2009 08:34 PM
looking @ 2001 Rio problem won't start 37coupe13 1G (2001-2005) Rio 10 09-23-2008 11:31 PM
2000 Kia Sportage Hard Start photog3740 1G (1993 - 2002) Sportage 0 12-16-2007 08:53 PM
Kia Sportage 2.0 TDI 07/2000 Engine does not start Shogi 1G (1993 - 2002) Sportage 0 07-03-2007 12:25 PM
