01 Sportage ran code P0560 after attempt to ground MAP sensor at Black wire with whit - Kia Forum
post #1 of 2 (permalink) Old 12-13-2007, 03:53 PM Thread Starter
Question 01 Sportage ran code P0560 after attempt to ground MAP sensor at Black wire with whit
Hi, Everyboby!
I have an 01 Sportage and while trying to make her run better, I ground the black wire with a white stripe on it. It is on the center with the red wire on one side and two grounds(black/yellow)on the other. While grounding this, I tried to start and of-course, she didn't. She was running before this test. I took out the ground hook-up and check the DTC and the code reads P0560 (voltage malfuntion). Anyone has any suggestions on what part could be affected by this test. Thanks, Harideva
harideva is offline
post #2 of 2 (permalink) Old 12-16-2007, 02:11 PM Thread Starter
Found problem. 15amp fuse to main relay. R/R and she started right up. No more P0560 code. Thanks to Ron1004 for support and suggestions that were right on. HD
harideva is offline
HELP - Install of Brake Controller 2015 Sportage - Elusive Red Wire Tap in Point yzripper 3G 2011 - 2016 Sportage 4 05-05-2016 04:55 AM
Kia Sportage (2012) FCEV ArunPillai 2G (2003-2010) Sportage 5 11-15-2009 11:53 PM
DIY Engine Grounding Kit Flipipino Do it Yourself 8 03-25-2009 02:42 PM
02 Cinco headlights dim while driving zfmrchnt 1G (2001-2005) Rio 2 03-19-2007 02:01 AM
80GB HDD Install!! Jonsey_MF54 Kia Picanto Forum 0 02-17-2007 02:57 PM
