**please help a/c clutch not engaging - Kia Forum
 3Likes
  • 1 Post By hookie
  • 1 Post By hookie
  • 1 Post By hookie
post #1 of 8 (permalink) Old 05-19-2019, 08:40 AM Thread Starter
Drives: 1998 KIA SPORTAGE 2 wheel drive 2.0 LITER , AUTOMATIC TRANSMISSION
Quoted: 7 Post(s)
Wink **please help a/c clutch not engaging
[B]HELLO we replaced a seized ac compressor with new OEM DAEWOO. 1998 KIA SPORTAGE 2.0 liter 2 WHEEL DRIVE. AUTOMATIC. ALSO REPLACED AC RECEIVER DRIER(FILTER). NO LEAKS,
WHEN I UNPLUG IT FROM AC COMPRESSOR WIRE..NO VOLATGE WITH AC ON???????????? WHERE IS THE AC FUSE FOR THIS CAR??????????
WHERE IN GODS NAME IS THE AC FUSE????? I LOOKED UNDER THE DRIVER SIDE..NONE AND NONE UNDER THE HOOD
I DO SEE 2 AC RELAYS UNDER PASSENGER SIDE.
THE ONLY PART WE DIDNT REPLACE WAS AC SWITCH WHICH SGREWS INTO AC RECEIVER DRYER~NO ONE HAD IT. NOT EVEN DEALER.
ALSO , WE HAD TO CUT THE NEW TERMINAL END OFF NEW AC COMPRESSOR WIRE AND REATTACHED OLD COMPRESSOR END TERMINAL AS THEY WOULD NOT FIT INTO WIRE HARNESS.. JUST CRIMPED THE OLD CONNECTOR ON COMPRESSOR WIRE FROM COMPRESSOR
***PLEASE HELP
I ASSUME BOTH PULLEYS SHOULD TURN WITH AC ON A/C CLUTCH AND AC PULLEY..BUT CLUCTH NOT ENGAGING OR CYCLING ON OR OFF.
NEW FREON
VACUUM SYSTEM,,,,PLEASE HELP
hookie is offline
post #2 of 8 (permalink) Old 05-19-2019, 10:04 AM
Drives: Sportage Limited 2001
Quoted: 4 Post(s)
Do you have voltage at the pressure switch?
Sent from my SM-G550T using Tapatalk
Steve_Sidwell is offline
post #3 of 8 (permalink) Old 05-19-2019, 10:14 AM
Quoted: 4 Post(s)
Also, is the rear wiper fuse good? Here's a diagram for the a/c system.
post #4 of 8 (permalink) Old 05-19-2019, 09:39 PM Thread Starter
Quoted: 7 Post(s)
finally got 13.5 volts at terminal plug of wire harness that connects to compressor so the compressor turns and so does the A/C clutch with AC dash button on.HOWEVER, there is no cold air blowing and the ac clutch doesn't cycle on and off..it just stays on.. someone said we need more FREON to activate the switch in top of ac drier.
I disconnected the plug that goes to ac switch on drier AND ON SIDE READS 5 VOLTS..THE OTHER SIDE READS AROUND ZERO..
Steve_Sidwell likes this.
hookie is offline
post #5 of 8 (permalink) Old 05-19-2019, 09:42 PM Thread Starter
Quoted: 7 Post(s)
[B][/B thank u sooooooo MUCH FOR YOUR HELP..REAR WIPER fuse is GOOD
I SE no ac fuse ON THIS CAR..SEARCHED FOR HRS.
I DO HAVE 13.5 VOLTS TO WIRE HARNESS THAT GOES TO AC COMPRESSOR. ALSO,COMPRESSOR CLUTCH TURNS WITH AC DASH BUTTON ON AND CAR RUNNING,
BUT AC clutch DOES NOT CYCLE ON AND OFF..SOMEONE SAID WE NEED MORE FREON AND THAT THE SWITCH IN AC DRIER IS NOT ACTIVATING..
no cold air blowing out of vents,
THANKS FOR DIAGRAM!
hookie is offline
post #6 of 8 (permalink) Old 05-19-2019, 09:57 PM
Quoted: 4 Post(s)
Welcome on the diagram, no a/c fuse, just what you see in the diagram. You need 40 to 45 psi on the low side and condenser fan running at idle, a/c on. My compressor doesn't cycle either, just stays on when a/c switch is on along with the inside fan switch.
post #7 of 8 (permalink) Old 05-21-2019, 09:52 AM Thread Starter
Quoted: 7 Post(s)
Steve any way u can make this diagram bigger for future use? I cant enlarge it
can you send it to my email blown up..hard to see
thanks
[email protected]
hookie is offline
post #8 of 8 (permalink) Old 05-21-2019, 02:12 PM
Quoted: 4 Post(s)
Message sent, hope it works.
Picanto GS Clutch issues :( chue12 Kia Picanto Forum 3 06-07-2018 12:10 PM
Clutch issues? rikkotec 2G (2006 - 2011) Rio & Rio5 3 12-04-2017 10:13 AM
95 Sportage Clutch issue Doctor_k1 1G (1993 - 2002) Sportage 5 10-03-2016 01:07 PM
A/C clutch not engaging Robert Carl Kia Cerato, Shuma & Spectra Forum 15 10-23-2015 07:19 PM
Hyundai Class Action Suit Filed Inky Kia News 1 08-25-2008 12:12 AM
