Random No Crank No Start - Kia Forum
post #1 of 3 (permalink) Old 04-21-2019, 11:52 PM Thread Starter
newjason's Avatar
Drives: 2000 Sportage 2WD 2.0L MFI DOHC 4cyl A/C 4 Door
Starting this 2000 Sportage has become like playing a slot machine with a key.
I have Good Battery Voltage.
I have cleaned/hooked up the negative grounding points and new battery connectors.
I have replaced the starter and main relays with KIA OEM relays. (they are yellow)
I turn they key and it will start right up sometimes.
Other times, I will turn they key and get a single Click.
After a few tries it will start.
The click sounds like it's coming from under the dash.
All the lights act normally on the instrument display panel, just sometimes it starts and sometimes clicks.
Is there an ignition switch relay under the dash somewhere?
I have read a few threads on this , but not a single one has a solution.
newjason is offline
post #2 of 3 (permalink) Old 04-22-2019, 07:52 AM
Drives: 2011 Forte SX 2.4L (thankfully MPI) A/T 131K miles
Quoted: 253 Post(s)
You can try diagnosing this a few different ways, but my first choice would be to try jumping the starter relay (bypassing the control side) immediately after getting a no-start (i.e. don't keep trying to start it with the key after getting the no-start). If jumping the relay does not turn the starter, then the starter or related wiring becomes the primary suspect. However, you also need to check for B+ on the always-hot side of the relay, in order for that testing to be valid.
kiaguy002 is offline
post #3 of 3 (permalink) Old 04-23-2019, 03:03 PM
Drives: Sportage Limited 2001
You can also get a test light, connect it to the starter solenoid terminal coming from the relay, then clamp to ground. Do this with a no start. If test light comes on with a no start, and solenoid don't click, make sure solenoid is grounded good to starter and starter to block. If it clicks, make sure you have battery voltage at solenoid from battery. And see if you have battery voltage from solenoid to starter with key in crank position.
Sent from my SM-G550T using Tapatalk
Steve_Sidwell is offline
2000 KIa Sephia MT (manual transmission) no start, no crank issues Learning 2G (1998 - 2001) Sephia 10 12-05-2017 01:51 PM
Motor Swap, Crank no start (auto to manual 4WD) LACoon70 2003-2010 Sorento Forum 11 08-08-2017 05:47 PM
2010 kia rio lx crank no start Uncleginger 2G (2006 - 2011) Rio & Rio5 5 06-06-2017 06:46 AM
2005 Kia Sedona - No Start / No Crank, Alarm TomInPA Kia Carnival & Sedona (2002 - 2005) 1 11-01-2015 08:12 AM
Intermittent start problem-seems heat/sun related entletank 2G (1998 - 2001) Sephia 6 05-11-2009 01:49 PM
