01 sportage no start - Kia Forum
 5Likes
post #1 of 69 (permalink) Old 03-26-2019, 09:44 PM Thread Starter
Steven Spellman's Avatar
Drives: 2001 Kia Sportage
Quoted: 23 Post(s)
I turned it on and got ready to pull out of the parking space when it died on me. Tried adding fuel bc it was low, no go. Can anyone suggest where to start? Can the fuel pump or relay die with the car running?
Sent from my SM-J727T1 using Tapatalk
Steven Spellman is offline
post #2 of 69 (permalink) Old 03-26-2019, 09:58 PM
Drives: Sportage Limited 2001
Quoted: 3 Post(s)
Both either one can go out at any time. I'd check all the relays and fuses first.
Sent from my SM-G550T using Tapatalk
Steve_Sidwell is online now
post #3 of 69 (permalink) Old 03-26-2019, 10:00 PM
Quoted: 3 Post(s)
May not hurt to check and see if any codes set in the engine control module.
post #4 of 69 (permalink) Old 03-27-2019, 04:25 AM
Quoted: 704 Post(s)
Question
What's the mileage and service history?
When last was the timing belt replaced?
ron1004 is offline
post #5 of 69 (permalink) Old 03-27-2019, 05:28 AM Thread Starter
Quoted: 23 Post(s)
Went to autozone the code the computer read was cylinder 3 misfire they suggested replacing the fuel injector. The other was a coolant temp sensor code but I replaced it already
post #6 of 69 (permalink) Old 03-27-2019, 05:29 AM Thread Starter
Quoted: 23 Post(s)
No clue about the timing belt and around 180k but I can verify when I get home.
post #7 of 69 (permalink) Old 03-27-2019, 05:59 AM
Quoted: 704 Post(s)
The most common sudden death cause is the timing belt failure.
A quick and easy first step in the diagnosis is to try starter fluid.
DavesSpectra and ReadO like this.
ron1004 is offline
post #8 of 69 (permalink) Old 03-27-2019, 09:18 AM
Quoted: 3 Post(s)
Use carb cleaner, safer than starting fluid, won't blow the head off. Should sound different when trying to start also if jumped timing or belt breaks.
post #9 of 69 (permalink) Old 03-27-2019, 09:23 AM
Quoted: 3 Post(s)
If timing is ok, I wouldn't jump in and replace fuel injector, I'd inspect plug, also use a spark tester to test coil for good blue spark. A few sparks then nothing is considered no spark and possibly a bad coil. I've also replaced my temp sensor and thermostat on my but still sets a code for thermostat below threshold. Only thing reads low is my gauge, sets around 170, ecm reads 200 at operating temp.
post #10 of 69 (permalink) Old 03-27-2019, 09:58 AM
Quoted: 704 Post(s)
Bear in mind that may be an old stored code, and the suggestion to move ahead with an injector replacement without proper diagnostics is what you may expect from an Autozone clerk - there's multiple possibilities, and some like a plug, coil or HT lead more likely than an injector.
Anyway, your current problem is not a "misfire", its a no start, so suggest the steps in my previous post.
ron1004 is offline
2001 Kia Sportage will turn over but not start. JoeyMark 1G (1993 - 2002) Sportage 10 03-24-2016 12:05 PM
200 Sportage won't start -code P0343 philko Kia Sportage Forum 3 05-12-2008 09:46 AM
'99 Sportage Start problem NeilsKia 1G (1993 - 2002) Sportage 1 01-27-2008 03:19 PM
Kia Sportage 2.0 TDI 07/2000 Engine does not start Shogi Kia Sportage Forum 1 07-09-2007 04:05 PM
Sportage that wont start Sportage_Monster 1G (1993 - 2002) Sportage 4 07-04-2007 11:05 PM
