01 sportage no start - Page 7 - Kia Forum
 5Likes
post #61 of 71 (permalink) Old 06-12-2019, 05:05 PM Thread Starter
Steven Spellman's Avatar
Drives: 2001 Kia Sportage
Quoted: 23 Post(s)
Question Coolant Temp Sensor
Has anyone had any difficulty with replacing theirs? I know it's a 19mm, but my problem is there is no clearance from any position to get a wrench or socket onto it. Can anyone offer any suggestions as to how they got theirs changed? Thank you.
Steven Spellman is offline
post #62 of 71 (permalink) Old 06-12-2019, 07:26 PM
Drives: Sportage Limited 2001
Quoted: 4 Post(s)
A thin wall 12pt should go right on.
Sent from my Samsung On5 using Tapatalk
Steve_Sidwell is offline
post #63 of 71 (permalink) Old 06-12-2019, 08:09 PM Thread Starter
Quoted: 23 Post(s)
Where do I find a thin wall wrench?
Sent from my SM-J727T1 using Tapatalk
post #64 of 71 (permalink) Old 06-13-2019, 06:17 AM
Quoted: 4 Post(s)
Socket, forget about a wrench. You can't get in there without damaging something. Deep thin wall socket and maybe a 6" extinction.
post #65 of 71 (permalink) Old 06-13-2019, 08:13 AM Thread Starter
Quoted: 23 Post(s)
Ok thank you!
post #66 of 71 (permalink) Old 06-13-2019, 08:02 PM Thread Starter
Quoted: 23 Post(s)
So I replaced the thermostat and the gasket as well as the CTS. Now I get code p0117. Could that cause a no start?
post #67 of 71 (permalink) Old 06-15-2019, 12:10 AM
Quoted: 4 Post(s)
P0117 Engine Coolant Temperature Circuit Low Input.*
post #68 of 71 (permalink) Old 06-15-2019, 12:19 AM
Quoted: 4 Post(s)
Go here, it will give you an idea what to look for, must have a scan tool and multimeter to test the system.
https://www.obd-codes.com/p0117
post #69 of 71 (permalink) Old 06-16-2019, 03:11 PM Thread Starter
Quoted: 23 Post(s)
Ok so I redid the timing my problem now is the tensioner and the other pulley. The other pulley seems to be getting grinded by the part where the tensioner spring connects to. Also is this part supposed to rotate when the belt turns?
The tensioner doesnt rotate freely when I started the engine. It rotates freely when I loosen the bolt but any slight bit of tightening it stops rotating. When I loosen the bolt it rotates but of course the bolt starts to back out as it rotates. I've seen other posts say its supposed to rotate when the engine turns the belt. Is that correct?
post #70 of 71 (permalink) Old 06-20-2019, 11:36 PM
Quoted: 4 Post(s)
Missing a spacer on the back side or is the pulley on backwards. When the bolt is tight it locks the pulley in place, should rotate freely.
2001 Kia Sportage will turn over but not start. JoeyMark 1G (1993 - 2002) Sportage 10 03-24-2016 12:05 PM
200 Sportage won't start -code P0343 philko Kia Sportage Forum 3 05-12-2008 09:46 AM
'99 Sportage Start problem NeilsKia 1G (1993 - 2002) Sportage 1 01-27-2008 03:19 PM
Kia Sportage 2.0 TDI 07/2000 Engine does not start Shogi Kia Sportage Forum 1 07-09-2007 04:05 PM
Sportage that wont start Sportage_Monster 1G (1993 - 2002) Sportage 4 07-04-2007 11:05 PM
