CAT Back - Kia Forum
 2Likes
post #1 of 19 (permalink) Old 03-24-2019, 09:11 PM Thread Starter
newjason's Avatar
Drives: 2000 Sportage 2WD 2.0L MFI DOHC 4cyl A/C 4 Door
CAT Back
I have a 2000 sportage 2wd that will not go beyond 50mph. Any rpm over 2000 it starts to sputter.
It has 1 02 sensor in the manifold and a second 02 sensor just beyond the warm up CAT. I have no codes at the moment , but I get 0300-0304 random misfires that will go away after not driving over 40mph or on the freeway for 1 or 2 drive cycles.
I took the temps with the engine warm.
Just beyond the pre- CAT 875F
Just before the main CAT 675F
Just after the main CAT 300F
Upon closer inspection the arrow on the main cat is pointing toward the engine.
It's A Kia CAT and has been welded before the cat and has a flange behind.
The number is K08B.
In the photos the front of the car is on the left .
My Question is, Can I just cut this mess out and replace it with straight pipe?
There is no 02 sensor beyond the main CAT So it can't possibly be monitoring the main CAT, So why do I need it?
Jason
ID:	104716   Click image for larger version
ID:	104718   Click image for larger version
ID:	104720   Click image for larger version
ID:	104722   Click image for larger version
newjason is offline
post #2 of 19 (permalink) Old 03-24-2019, 09:18 PM
Drives: Sportage Limited 2001
There should be an o2 sensor right after the main cat, not before the main cat. It's on backwards for sure. Fuel filter clear?
Sent from my SM-G550T using Tapatalk
Steve_Sidwell is offline
post #3 of 19 (permalink) Old 03-24-2019, 09:19 PM
Front senor monitors pre cat, rear monitors post, (rear) cat.
post #4 of 19 (permalink) Old 03-24-2019, 10:23 PM Thread Starter
newjason's Avatar
I'll replace the fuel filter tomorrow.
I'm assuming the main CAT 02 sensor(s) are not there because the CAT was installed backwards.
There are just 2, no more downstream.
ID:	104726   Click image for larger version
newjason is offline
post #5 of 19 (permalink) Old 03-25-2019, 01:47 PM
Should be just two, one sensor after the first converter and one after the second.
post #6 of 19 (permalink) Old 03-25-2019, 01:53 PM
Quoted: 674 Post(s)
Looks like your vehicle is only monitoring the first CAT, so would have no control issues replacing the second CAT with a straight through pipe, other than the impact on the environment and possibly not passing an inspection.
ron1004 is offline
post #7 of 19 (permalink) Old 03-25-2019, 06:54 PM
More than likely designed like the 80's American cars, only monitoring before the first converter for fuel control and added the second to make sure the precat was working properly. I'm used to them monitoring all converters.
post #8 of 19 (permalink) Old 03-25-2019, 11:39 PM Thread Starter
newjason's Avatar
I replaced the fuel Filter, and I can't detect a change.
Thinking about it last night , a straight pipe would be a bone head move ,
so I am going to replace the main CAT with a new one.
So, I will need to tap a bung on the pipe past the main CAT,
move sensor 2 to that new hole,
move sensor 1 to sensor 2's old location and,
plug the hole left where sensor 1 previously was?
OR
Should I just leave the sensors alone and just replace the main CAT?
thanks for the advice.
Jason
newjason is offline
post #9 of 19 (permalink) Old 03-26-2019, 07:50 PM
I went and looked at mine. Mine has it in the manifold and the second right after the precat. So, someone must has just installed your second converter backwards, won't cause a problem.
post #10 of 19 (permalink) Old 03-26-2019, 07:52 PM
Too bad the rear converter couldn't be unbolted from the system to see if it was clogged.
Kia Sorento EX Automatic Transmission Change Richard Fritz 2011 - 2013 (XM) Sorento Forum 8 08-22-2018 04:32 PM
Here is how to change the Sorento EX 2.4L Automatic Transmission Fluid Richard Fritz Do it Yourself 0 07-29-2018 03:54 PM
2015 Sedona Easy Seat Back Not Working Danielle Cousin Kia Carnival & Sedona 2015+ 1 12-25-2015 10:16 PM
Noise in the back Pinbot Kia Cee'd Forum 46 01-24-2011 03:55 PM
