Downstream o2 sensor heater resistance 98 kia sportage - Kia Forum
 4Likes
  • 1 Post By hookie
  • 1 Post By hookie
  • 1 Post By hookie
  • 1 Post By Markfothebeast
LinkBack Thread Tools
Old 09-27-2018, 08:59 AM Thread Starter
Drives: 1998 KIA SPORTAGE 2 wheel drive 2.0 LITER , AUTOMATIC TRANSMISSION
Quoted: 7 Post(s)
HELLO can anyone help here 1998 KIA SPORTAGE QXYGEN SENSOR- lower one
Do you know what the HEATER resistance is suppose to be on a 1998 KIA SPORTAGE downstream bank 1 sensor 2 (OXYGEN SENSOR) after the catalytic converter.
I need to know the correct OHM READING between the two white heater wires to see if heater is good inside
the parts store has diff. brands o2 sensors, and i get different readings on my meter.. The Kia Dealer will not let me ohm an electrical item of theirs to check.
**PLEASE give me correct reading in OHMS .
thank you!!!
hookie is offline
Old 09-27-2018, 10:25 AM
Drives: Sportage Limited 2001
Quoted: 3 Post(s)
Don't know about the rear but I replaced my front one and same code popped back up for the heater again. New heater had 5 ohms of resistance so I know it has to be lower than that. I do have power and ground for it to work, even tested it before I installed it, so I thinking maybe 2.5 ohms.
Sent from my SM-G550T using Tapatalk
Steve_Sidwell is online now
Old 10-02-2018, 09:27 PM Thread Starter
Quoted: 7 Post(s)
STEVE thanks to you..my check engine lite was on for my downstream o2 sensor for yrs! I ohmed the old O2 sensor and it was 7.9 ohms..put a new one in that was 2.5 OHMS..works prefect and no more codes or check engine lite after reset!!!! THANKS LOADS!!!!!!!
Steve_Sidwell likes this.
hookie is offline
Old 10-02-2018, 11:43 PM
Quoted: 3 Post(s)
No problem, I knew it has to be less than 5 ohms.
Old 10-02-2018, 11:45 PM
Quoted: 3 Post(s)
May I ask, where did you get yours, hard to find one with the correct resistance except from the stealer.
Old 10-04-2018, 06:38 PM Thread Starter
Quoted: 7 Post(s)
purchased them yrs ago on EBAY
they came in pairs..
no purchase info or brand or name of Company
if I find any info, will definitely let you know
thanks again!
hookie is offline
Old 10-10-2018, 09:14 AM Thread Starter
Quoted: 7 Post(s)
Hi Steve I found the correct part ..the oxygen sensor with 2.5 ohms that works is made by WALKER, PART # 250-24341 you can get on ebay;
*LISTED BELOW >>SCROLL DOWN..HOPE THIS HELPS
Details about Walker Products 250-24341 Oxygen Sensor - Walker
Condition: New
Price: US $17.64
https://www.ebay.com/itm/Walker-Prod...2:pf:0&vxp=mtr
hookie is offline
Old 10-10-2018, 10:29 AM
Quoted: 3 Post(s)
Walker is pretty good, running a Mass Air Flow sensor made by them. Thanks for the info bro.
Take care with this storm and stay safe.
Old 11-06-2018, 02:10 PM
Drives: 02 Sportage, 95 Trans Am, 05 Crossfire, 04 Venture
Quoted: 29 Post(s)
I had o2 problems that were caused by multiple issues. The first was a cracked exhaust manifold that threw the emmissions o2 out of range. The second was a poor connection in the tight wiring harness behind the engine. I cut the connectors and wired in the harness wiring and o2's I had laying around from a Caravan 3.3L engine. Had no issues since.
MikDee likes this.
Markfothebeast is offline
Old 05-26-2019, 11:03 AM
Drives: 2001 Sportage, FE DOHC Engine 5 SPD Manual Petrol
Quoted: 10 Post(s)
The service/repair manual says 5 ohms.
The cat will set a code at only 5 percent blockage. Pour some laquer thinner in the upper sensor hole to clean the pre cat heater. You can also spray sea foam and let it hot soak for 15 minutes too. If the code goes away you will know it was the cat setting the code.
Videos on YouTube about using laquer thinner.
ZorgEntity is offline
2017 Sportage - US info conwelpic 4G 2016-2018+ Sportage 33 10-08-2016 08:00 AM
2009 Sportage: 1,000-mile review Rottenbob 2G (2003-2010) Sportage 14 07-07-2013 12:27 PM
Kia Sportage (2012) FCEV ArunPillai 2G (2003-2010) Sportage 5 11-15-2009 11:53 PM
1995 Sportage Camshaft Position Sensor Resistance kcreek33 1G (1993 - 2002) Sportage 0 02-23-2009 08:44 PM
