2000 Kia Sporage Rear Axle Removal 4x4 - Kia Forum
 1Likes
  • 1 Post By aquanaut20
post #1 of 4 (permalink) Old 06-27-2017, 11:02 AM Thread Starter
Drives: 2000 Kia Sportage
Hello everyone,
I have had my first Kia Sportage for about 6 months now, and it has been ok. It is a fun little car but has had its issues.
The latest for me is a bad rear wheel bearing. Drivers Rear.
I have took the wheel and drum off but left the backing plate on. I took off something that had 4 bolts that looks like retainer that I thought would allow me to remove the axle, but after I took it off the I was still not able to pull the axle out. It would only slide a little then stop pretty solid.
I am looking for tips on how to get the axle out. Can it slide out with the brake backing plate still on? Is there a retainer inside the diff I need to undo first?
I see there are already helpful threads on the wheel bearing subject, but not on axle removal.
Thank You. 2000 Kia Sportage 4x4
Wisebrow1 is offline
post #2 of 4 (permalink) Old 06-27-2017, 01:59 PM Thread Starter
Aye, so 4x4 wire has a good thread on this already.
4x4wire.com/forums/ubbthreads.php/topics/1045582.html
The 4 bolts I was talking about was the retaining plate and the axle should slide right out once thats unbolt. I will have to try again with more force.
post #3 of 4 (permalink) Old 06-27-2017, 04:53 PM
aquanaut20's Avatar
Quoted: 251 Post(s)
The bearing is a friction fit, so you will need to shock it loose (slide hammer/reversed drum).
... Philip
Wisebrow1 likes this.
aquanaut20 is offline
post #4 of 4 (permalink) Old 07-12-2017, 11:13 AM Thread Starter
Thanks for the tip, reversing the drum is clever. Mine came out with some moderate prying. I wasnt trying hard enough before
I replaced the leaking wheel seal (proper tool highly recommended or atleast a large socket for installing) and re greased the bearings.
Thanks again.
Attached are pics of the locknut and lock washer (with folded over tab) and bearing housing. In my pic the race is seized into the axle housing. I couldnt get it out or the locknut off so I gave up. Re greasing the bearings reduced some nasty noises, for now.
Name:	bearing and seal 1.jpg
ID:	86753   Click image for larger version
Name:	kia bearing seal 2.jpg
ID:	86761   Click image for larger version
Name:	kia race inside.jpg
Rear Axle Seal and Bearings 2000 Sportage cville 1G (1993 - 2002) Sportage 0 12-31-2016 08:37 AM
Rear axle identification Veebidge 1G (1993 - 2002) Sportage 4 07-11-2015 08:38 AM
04 sorento ex v6 3.5 A/T rear axle bearing battlezzz 2003-2010 Sorento Forum 3 10-12-2009 12:13 AM
Kia Sedona 2000 rear seat removal leekia2007 Kia Carnival & Sedona Forum 5 05-26-2007 01:00 PM
Bent Rear Axle wedge 1G (1993 - 2002) Sportage 1 07-11-2006 05:27 AM
