Best Tire Size 2002 Sportage 4WD RWD - Kia Forum
 2Likes
post #1 of 16 (permalink) Old 03-16-2016, 06:24 PM Thread Starter
I dont wheel around that much but its getting close to summer and its time for new tires. I Have an up hill gravel driveway and a 12 (Maybe take a few) miles on backroads to work i make.
I want a little bit bigger tires but still get good mpg dont know what to get.
Suggestions?(:
Aj<3
Ashlyn Jenea Dodds is offline
post #2 of 16 (permalink) Old 03-17-2016, 08:05 AM
Drives: 97 Sportage,Landrover Disco II
Quoted: 13 Post(s)
Try a 215 /75 r 15 or 235/75 r15
They will give you a bit more height without affecting your power and economy to much. Also fit without lift and on your standard rims.
Cheers, Chris
97 Sporty 4" lift, 50 mm extended front forks, 5.38 R&P's, Kaiser front difflock, snorkel, 1 3/8 body lift, sports steering wheel, wild cat extractors & 2 1/4 " exhaust Fully Engineered.
4runnernomore is offline
post #3 of 16 (permalink) Old 03-17-2016, 01:28 PM
Drives: 1999 Sportage A/T 4WD
Quoted: 52 Post(s)
Wheels not designed for your car will modify the scrub radius resulting in a lesser steering grip; but if you do not speed on turns perhaps you could not notice that.
Galf is offline
post #4 of 16 (permalink) Old 03-17-2016, 03:36 PM
Ovidiu Crトツiun's Avatar
Drives: KIA Sportage Grand 2000 128HP Silver
Quoted: 21 Post(s)
235/75/15
Very usefull in my oppinion.
Name:	Tyres235 75 15.JPG
Smile now, tomorrow will be worst... :)
Ovidiu Crトツiun is offline
post #5 of 16 (permalink) Old 03-17-2016, 06:41 PM
Drives: '02 Sportage 2 door.
Quoted: 31 Post(s)
215/75/15 or 225/75/15 is what I recommend. A 235/75/15 may rub, especially if your springs are weak.
I get around 20-21 highway with the 5 year old 215/75/15 on mine.
Early summer they are going by by and a 4" lift and 31/10.50/15 are going on.
promodmerc is offline
post #6 of 16 (permalink) Old 03-18-2016, 02:05 PM
Drives: 02 Sportage, 95 Trans Am, 05 Crossfire, 04 Venture
Quoted: 29 Post(s)
I was considering the opposite. I would prefer to lower this vehicle because of it's narrow wheel base and top heavy feel. Bigger tires seem like more work on the tiny 4 banger also.
Markfothebeast is offline
post #7 of 16 (permalink) Old 03-18-2016, 04:07 PM
Quoted: 52 Post(s)
I think you would benefit from adding a rear stabilyzer bar to your Sportage:
http://addco.s3.amazonaws.com/wp-con...12/03/2037.pdf
http://www.andysautosport.com/products/addco__2037.html
Ovidiu Crトツiun likes this.
Galf is offline
post #8 of 16 (permalink) Old 03-18-2016, 05:14 PM
shapeshade's Avatar
Drives: 97 sportage 06 forester XT
Quoted: 46 Post(s)
hmmm now i gotta buy that sway bar =). I run 235/70/15 minimal rub. H&R make a lowering spring but dont run stock dampers if u dont like bouncy. Also have the 30mm spacers in the rear. Tires made the most improvement. It does take corners faster now >)
shapeshade is offline
post #9 of 16 (permalink) Old 03-18-2016, 10:58 PM
Quoted: 13 Post(s)
At a guess from these comments your suspension is still standard and most likely worn out.
My Sport with 4 inches of lift and running 245/75R16 (almost a 31inch tyre) tyres handles like it is on rails even with that extra height.
Buy some new shocks and springs and it will transform your ride. Also look at your suspension and steering bushes as well for any signs of wear.
New suspension is the way to go. Just get a mild lift 40mm.
Cheers, Chris
post #10 of 16 (permalink) Old 03-27-2016, 11:30 PM
Drives: 2001 Sportage, FE DOHC Engine 5 SPD Manual Petrol
Quoted: 10 Post(s)
I'm going to Walmart, and get 235/75/15 Goodyear Wranglers. ($73.00 right now). Black wall out. Will barely notice that their slightly taller, and will probably compensate for the wear in the springs, and such. Get a cheap wheel alignment to go with them. So many potholes and bumps in the roads these days the extra meat will help. Hell the cars 15 years old, and it takes me everywhere. I did the math, and it will barely add a 1/2 inch between the tire, and the road if that much. Also there's plenty of room in the well.
ZorgEntity is offline
2017 KIA SPORTAGE OEM SPARE TIRE AND Auto Dimming Mirror w Built-in Digital Compass silverboy Parts For Sale / Trade 5 01-21-2018 02:02 PM
2015 Sportage A/T tire help shawnkva 3G 2011 - 2016 Sportage 3 09-09-2015 08:02 PM
Kia Sportage (2012) FCEV ArunPillai 2G (2003-2010) Sportage 5 11-15-2009 11:53 PM
2002 optima tire size? frankoli Kia Magentis & Optima Forum 2 12-26-2008 05:44 AM
Tire size UrbanRondo Kia Carens & Rondo Forum 19 10-28-2008 09:21 PM
