Originally Posted by dietDrThunder
I know that the OEM wheels on my car are 16" 4x114.3 , with 43mm offset (according to a post here...thanks). The OEM tires are 205-50/16. I"m looking at some after market wheels that are 17" w. 40mm offset. The tires I'd use would be 215-45/17. Do you guys think this combo should fit ok? I can't seem to find any 43mm offset wheels, but it's hard to believe that the 3mm makes a huge difference.
Thoughts?
1) 3mm less offset will only put the wheels out of the fenders 3mm more. Should not be an issue if NUMBER 2 is kept in mind.
2) What ever tire/size you use make sure it is the same overall diameter as the OEM one and your fine. Speedo and clearance issues will be kept to a minimum then.
3) IF you do not find a rim with teh same OEM offset. A alignment is a must have when you change them. AS it is based on the OEM offset and not the new one. If you switch back and forth from winter adn OEM rims with out the same offset. Then you do two aligns a year. OR be up for tire wear.
