2003 Spectra
I have been having this problem for about 3 years that has progressively gotten worse.
After the car has sat for awhile, your turn the key and the only thing that happens is the lights on the instrument panel light up (seat belt, check engine, etc) just like normal. But the starter doesn't crank. If you sit there long enough with the key turned it will sooner or later kick and start up and run perfect.
Problem now is that sometimes you have to wait 2 minutes or more for this to happen.
Starter is strong; battery is new; cables look good.
Kia dealer the last time I took it to them said they couldn't duplicate the problem; which I found to be unbelievable since it happens all the time.
Any suggestions other than selling it??
