code 1404 - Kia Forum
post #1 of 6 (permalink) Old 09-23-2011, 01:11 PM Thread Starter
Drives: 2013 soul plus-2013 soul exclaim
code 1404
My 2002 spectra ls 1.8L has the ck. engine light on with a code 1404 "heater module leak detected". Car runs great, just the ck. engine light stays on. Can't find this 1404 code explanation anywhere. Can someone help me with this or at least point me in the right direction? Thanks.
oldwrench is offline
post #2 of 6 (permalink) Old 09-23-2011, 01:29 PM Thread Starter
Also, when the light first came on i disconnected the battery to clear the code. It stayed off for 3 days and then returned. Both times the light came on after a hot soak condition when I started the motor back up.
post #3 of 6 (permalink) Old 09-24-2011, 07:56 PM
Pacosworld's Avatar
Quoted: 13 Post(s)
P1404-1 DMTL Power Stage(motor)
P1404-2 DMTL Power Heater
P1404 Leak detection module solenoid valve circuit malfunction
The DM-TL (Diagnostic Module Tank Leakage) is used to monitor the evaporative system for leaks. The diagnostic module consists of an air filter, an electrical driven air pump, a change-over valve and a 0.02 inch orifice for reference measurement . Heated type Module applied to improved Leakage Detection Module. Using the heated DM-TL can completely eliminate the humidity influence. So, the Leakage detection is never stopped caused by the current fluctuation (due to dew effects at extreme high humidity).
If the value exceeds threshold value, the ECM judged this as a fault and DTC is set.
You'll want to follow the EVAP line from the charcoal canister in the underchassis and it should lead you to it.
Mike AKA Paco
Pacosworld is offline
post #4 of 6 (permalink) Old 09-24-2011, 08:09 PM Thread Starter
Mike, thanks for your reply. Now I know where to look and what to look for. It is great to have web sites like this and people like you willing to share their knowledge.
post #5 of 6 (permalink) Old 10-28-2011, 06:13 AM
Mike,
Very thorough answer to the question. Just a small follow-up. I've looked at all of the parts diagrams on quite a few kia parts sites and cannot find anything remotely called DM-TL, or air pump, or Leak Detection (with or without "Module") .
If this item is bad, what is the Kia nomenclature for it so that I can order one? Is it all part of the solenoid assembly?
Thanks in advance, Bob in NC
bobainsworth is offline
post #6 of 6 (permalink) Old 10-28-2011, 07:34 PM
Pacosworld's Avatar
Quoted: 13 Post(s)
Originally Posted by bobainsworth View Post
Mike,
Bob,
PM me your VIN so I can locate a part #.
Mike AKA Paco
  Kia Forum > KIA Models > Kia Cerato, Shuma & Spectra Forum > Shuma & Spectra (1997-2003)
