I have just noticed that everytime i stepped on the brake pedal the brake lights won't come on. I searched the threads and found two here but am not sure that it helps because the thread mentions a stuck plungger near the pedal and that the brake lights were on and off intermitently, well mine is totally out and i have checked it is not the bulbs.... I called the workshop to ask what might the likely cause of the disfunction, and was told it was was most probably the brake switch. Is the brake switch and the plungger the same thing? Can it be fixed without bringing the car to the workshop...? thanks alot people, any help is greatly appreciated....
You didn't say what vehicle, but my 2006 Sedona switch failed and my 2007 Rondo switch failed. Both were replaced under warranty. The switch is located up under the dash on or hear the brake pedal arm at the servo attachment.
From the kiatechinfo.com site.
The full power feed for the brake light circuit....
from battery (+) post to fuse BTN (30amp in engine compartment) to fuse Stop(15amp in cab of car) to the brake light switch(mounted on steering column), to the brake light lamps (rear of car), to ground wire bolted to body of car (by the brake light lamps).
Would it be possible to send me the link to kiatechinfo, I opened up the panel under the steering column but could not find the fuse box or anything there..... Thanks again...
Pretty simple.... the "link" to kiatechinfo is as simple as typing kiatechinfo.com into the address box at the top of your internet browser and pressing enter....
You MUST be running windows and using Internet Explorer (both Microsoft products) and also have downloaded and the SVG plugin from Adobe to use the site. It won't work with Mac or Linux.
The fuse panel would be shown in the owner's manual along with the labels I posted in my last message.
Hi Guys
I noticed today my cruise control quit working, also that I have no brake lights. After changing the switch at th break peadle had nothing. Checked the brake light behind rear window it was out. Changed it and cruise starting working,also both LR brake light bulbs where blown. After I got 1 break light bulb burning my cruise started working.
Follow up my car is a 06 Optima 2.4L stright drive nothing but trouble. Changed crank shaft sensor 4 times, timing belt twice, low beam head light bulbs ever 2 months first the left then the right never the one I just changed. Talked to kia about this, they told to me have the dealer ship change bulb I did while under warrety still $50 buck.
Can anyone Please help me ? I have a 2006 Kia spectra and brake light's will not come on . I changed the brake switch , the fuses don't look bad. the bulbs are good . Now I'm lost at what to check. I didn't change the fuses but I thinking I will try that tonight.
I'm having the same issue with my 2011 Optima. Changed out the brake light switch, examined all fuses under the dash and in the engine compartment, no blown fuse. my tail light turns on but the brake when pressed nothing all 3 brake lights doesn't light up. Any idea, thank you.
Man, from the looks of all the different posts about malfunctioning brake lights and faulty electrical, I'm surprised Kia hasn't been sued. All of us out here driving with no brake lights for lord knows how long before we found it... no good. I almost got rear ended 3 times coming off the expressway.
