strange eletrical problem - Kia Forum
Old 01-19-2013, 07:46 AM   #1 (permalink)
NELSON30213's Avatar
Default strange eletrical problem
headlights on left side shines dull, horn wont work and cruise control wont work, but when the horn works cruise works and headlight shines bright.
i am thinking a bad ground somewhere any help appreciated
NELSON30213 is offline   Reply With Quote
Old 01-23-2013, 02:28 PM   #2 (permalink)
or a fuse or relay might be going out on you....
mnsandman is offline   Reply With Quote
Old 01-25-2013, 07:22 PM   #3 (permalink)
Drives: 2000 Kia Sportage 4x4 manual, (Daily Driver)..
Greetings Nelson,
You asked about grounds, there are (2) ground points associated w/ those accessories, they are located at:
Ground point G200: behind drivers-side lower kick panel, ground ring mounted to frame behind / below passenger cabin fuse box,
Ground point G102: parallel to & immediately to the right of the Driver's side headlamp assembly: follow the wiring harness above the headlamp -> to the side of the Driver's headlamp, - you are looking for a 14 gauge (black) wire that exits the harness, trace that wire down alongside the headlamp assembly -> to the ground ring & bolt, located on the driver's side fender, about 5 inches down from the top of the headlamp assembly,
Also recommend cleaning these ground points:
Battery terminals,
Neg. battery cable to ground tray,
Ground tray -> engine ground strap,
Ground tray -> frame bolts: remove battery, lift plastic cover, there should be (3) or (4) bolts securing the ground tray to the frame: clean up the bolt threads & bolts: replace w/ stainless bolt hardware if badly rusted, sandpaper or steel-wool all ground rings clean, use a thin coat of dielectric grease on everything when re-installing.
Hopefully inspecting / & cleaning up these ground points will help,
Regards,
GottaCruise
Kia Tech Info site: http://www.kiatechinfo.com
Laptop/USB OBD-II Scanner at Amazon: http://tinyurl.com/3jjf7xz
OBD-II Codes: http://www.obd-codes.com/trouble_codes/
GottaCruise is offline   Reply With Quote
Old 01-25-2013, 10:13 PM   #4 (permalink)
DavesSpectra's Avatar
Follow GottaCruse and your problems WILL be solved... IT IS a ground problem...You just need to find where...
DavesSpectra is offline   Reply With Quote
