fuel refill problem
HELLO FELLAS!!
RECENTLY WE START TO HAVE PUMPING GAS INTO THE TANK ! ,WE CAN'T POUR IT THE GAS NOT EVEN SLOWLY, THE PIPE GETS OVERFILLED AND BLOW GAS BACK!
AFTER A FEW CHECKS , HERE AND THERE , I DISCOVER A BREATHER-FILTER LIKE DEVICE , LOCATED UNDER THE BACK DOOR +- 12" X 8" X 6" WITH 2 HOSES CONNECTED , ONE 1/2" OTHER SMALL LIKE 1/4" PLUS A WIRE,.
I DESASSEMBLY THE WHOLE UNIT ( ATTACHED WITH 4 HEX 10 mm BOLTS )
AND THE ELECTICAL PLUG THAT HAS AN SQUARE " U" SHAPE CLIP HOLDING IT TO THE ON-OFF SOLENOID VALVE!
I COULD NOT FIND ANYTHING ALIKE ON THE PARTS SALES PAGES , NOR BY F
PHOTO OR NAME, SO I DECIDE TO FIX IT MYSELF .
BLOWING THRUE THE HOLES I FIND SOME RESISTANCE , SO I GET RID OF SOME OF THE CARBON PELLETS THAT FILLS IT THE DEVICE , UNTIL I CAN BLOW IT THRU MORE FREELY , I INSTALL ALL BACK AND WENT TO THE GAS STATION TO FILL IT UP .
RESULT: SUCSESS !! I FIILIT AT FULL SPEED WITH NO BACK UP BLOW OF THE GAS !! ,
I HOPE THIS CAN HELP YOU GUYS WITH THIS PROBLEM !
LUIS FEHER ORLANDO FL .
