Old 08-29-2009, 03:21 PM   #1 (permalink)
Wim44
Default KIA SPORTAGE 2007 (version: 2004-2008)
For Pioneer F910BT navigation system in my KIA Sportage I need some specific wires, connections of the KIA.
Between the KIA connector and the Navigation system there is a KIA2ISOadapter cable. To the ISO connector A+B the navigation system Pioneer F910BT is connected.
Questions related to navigation wires:
where can I find those wires in the car and which colors do these wires have ?
1/. handbrake wire / signal:
2/. speed pulse wire / signal
2a/. speed pulse signal, has it to be calibrated to some value in the KIA Sportage 2007. Nav. unit Pio Avice F910BT, I got Wd = 2500 pulses/km (kilometer).
2b/. if no scope present or multimeter, can I check for the pulse on navigation system by driving and removing the GPS connector from the navigation unit of the GPS antenne
3/. reverse signal wire, is this available in KIA on a connector
3a/. or should/nust reverse signal wire be connected to back lights which turn on, when driving backwards in reverse direction ?
3b. Pioneer provides a violet/white wire with fuse for backlight connection.
Can this signal be tapped from other location than backlights?
4/. some navigation systems need constant 12V power voltage and in addition a switched/controlled 12V voltage.
4a/. which wire is the constant 12V wire for this connection?
4b/. which wire is the switched 12V wire for this connection ?
5/. does the Sportage have an ETACS unit, where is this unit located ?
6. can a anti-theft system interfere with the signals needed by the navigationsystem. When I start my car the navigation system does not remember the most recent position where the car was parked. When riding the GPS recovers after about 1 km of riding were I am located.
(switched/constant connection reverse ? or some other reason?).
7. the previous navigation system was a Pio AVIC D3(BT). As far as I know this unit is compatible on the ISO connection level signals with the AVIC F910BT navigation unit. I never had D3(BT) troubles. The F910BT does not remember most recent parked location (motor switched of for longer time) and after recovery the arrow indicating the car is ahead on route or just on the map if no route in the system, just using the map. The screen on the navigation unit shows the car 50m in advance of the real position on the map.
Reason why I want to check the speedpulse and the constant/swithed 12V voltage connections.
Is there a wiring diagram available or a maintance manual in PDF format or book format. The dealer and companies who did provide and install this equipment do not provide this information and did a bad job....
Thanks In Advance
TIA
W
Wim44 is offline   Reply With Quote
Old 11-12-2009, 10:15 PM   #2 (permalink)
spicewood515
2005 the car was totally revamped. You sure about 2004?
spicewood515 is offline   Reply With Quote
