Originally Posted by ron1004
Another typical cause of brake binding, is corrosion of the brake hydraulic pistons and cylinder bores due to moisture in the brake fluid
The brake fluid is hygroscopic and retains moisture which leads to the corrosion.
Oh yes, forgot that
Let me add something to that, though.
Corrosion is one problem, but more important is lowered boiling point of the brake fluid. Water boils at +100C, as we know brakes get much hotter and brake fluid as well. In case of hot day, several braking on downhills or towing... it may happen that this moisture saturated brake fluid will start boiling what will cause feeling of not bleed brake system. In one word - no brakes. Brake pedal will travel to the floor - only fast pumping would help in this case.
For interval times for brake fluid changes - around 2 years (location dependent - hot, warm, dry states or cold, rainy...). You can do boiling test or color test - the darker, the worse it is.
