Help 2000 sportage Misfire
Long time readed, firt post, Glad to be here.
Alot of problems but 1 in particular. I got this car over a year ago and I changed the spark plugs. well 1 of the plugs had been cross threaded into the hole. well I tried to rethread it and I think the hole is to big, so my friend tells me to try a heli coil, tried that and It didn't fit. So Im pretty sure that It is not running very good because it is having compression problems.
My car takes a couple of seconds at every light to get up to speed. When I do get up to 25 I press the hold button to rev higher and get going. I know I cant do this forever but I sure would like a cheaper fix. I had it read and cylinder 4 misfires, same one the spark plug was in. Becides that my driver side window regulator and engine stopped working. needs new brakes, tire rotation, and the axels need work. please help!
