How fast and hard is it cranking? Is it cranking like it normally does? Or is it slow and ponderous? If the latter, Carlos might be right if all of the connections between the frame, engine, starter and battery are sound. A poor connection can sometimes cause a starter to act like the battery isn't supplying enough juice.
If the former, check the ignition and the filter. Filters are cheap enough, so I might replace it out of hand. Also, that motor uses a timing belt and not a timing chain. You'd be better served checking the coil packs.
It ain't broke till you can't fix it anymore.
