2000 kia sportage starting problems
my 2000 kia will not start unless you hold down on the gas peddle to the for then when it idles it idles rough like its got a miss in it but when you give it gas it runs fine and after it warms up and you shut it off it will not start again until you let if cools back down when i bought this sportage it started to act up on me when you go to start it some times it would start just fine and some times it would not if you keep tuneing it over it finly would start. then i was driving down the road and i was pulling my lawnmower and it got hot so i had a machinic do a compretion check on the cellinder the to back ones had a 100psi and the to front one had 60psi so he took the head off and had it redone. i have changed the crankshfte sensor on it, the camshaft sensor on it, the spark pugs wires idle senor on it airflow sensor on it. the temiture sensor on it. can anybody help me with this problem please thank you jeremy lefler.
