I have a Kia Sportage 2002 2 WHEEL DRIVE and change the spark plug BKR6E-11 NGK but i have problem with the start and slow to accelerated, i check the spark plug wire and the wire is ok.
OK, so it sounds like something that was removed to get at the spark plugs is either damaged or loose.
The large throttlebody tubing contains several electronic sensors -- make sure they are OK... no broken wires, etc. Also, where the throttlebody intake tube connects there is a gasket -- make sure that it is not damaged.
Harry
That code points to a lean condition which most often is an inlet manifold vacuum leak, but not the only possibility.
Make sure that the flexible rubber pipe between the MAF and the throttle body is in good condition.
Also make sure that the spark plug gaps are at 0.75mm - many documents specify a 1.0mm gap which is incorrect.
P0171
Related Items
1)Faulty fuel delivery system.
2)Clogged fuel injector(s).
3)Faulty fuel injector(s).
4)Leak in intake system.
5)Leak in exhaust system.
6)Faulty Mass Air Flow Sensor.
7)Faulty Throttle Position Sensor.
__________________ For service info register (free) with KiaTechInfo and click on 'Shop' on the left, and for elect schematics click on 'ETM'.
Given the circumstances, I agree with Ron -- likely a vacuum leak of somekind... especially if you hear a "hissing" noise on the top of the engine.
Next would be the fuel filter (to remove, just push inward each connector, then squeeze the release points, then pull outward to remove).
Finally, I would guess the MAF sensor, which is easily tested -- warm the engine and find the pin #4 wire (Red/Green) and see if the voltage is between 0.8 volts and 1.2 volts at idle; then, increase the RPM to 2000 RPM and see if the voltage is between 3.5 volts and 4.0 volts... if not, then replace it (about $90 at AutoZone).
I check the MAF Sensor in the pin 4 wire (red/green) and the voltage is 0.8 volts and 1.2 volts at idle, but when increase the RPM tu 2000 RPM the voltage is 1.6 volts.
