Old 04-06-2007, 10:21 AM   #1 (permalink)
Kats96sportage
Kats96sportage's Avatar
Drives: 1996 Sportage EX 4x4
Send a message via AIM to Kats96sportage Send a message via Yahoo to Kats96sportage
Angry could it be the alternator?
ok! here is the situation i am experiencing this time! I had an important appointment Monday and going out to start my 96 sportage, all it did was click when i turned the key.now this vehicle has been starting and running fine till Monday. Now i have to jump the battery to get going, and it wont hold charge. so if i go anywhere i need to be jumped. my battery isnt quite a year old, so i doubt its that, could it be the alternator? how can i be sure?
Kats96sportage is offline   Reply With Quote
Old 04-06-2007, 11:11 AM   #2 (permalink)
danvhp
Run it by AutoZone. They will check the condition of the electrical system and that will take the mystery out of what is wrong. Good luck!!!
danvhp is offline   Reply With Quote
Old 08-11-2007, 02:38 PM   #3 (permalink)
WA2YNE
Smile
One can, with an inexpensive digital voltmeter, check the charging voltage.
A battery by itslef should show around 12.5 volts, give or take if reasonably charged, Lower indicates discharged battery.
On a low battery, it will usually show around 12.5 volts or more after the engine is started, and should gradually climb to 13.8 to 14.4 volts. A few vehicles will show a higher voltage. If it climbs too fast from a dead batter, then most likely the battery is NG. If it never gets up to at least 13.8 volts, then it's likely the alternator or regulator is bad.
For the record, with one or more diodes blown in the alternator, it will still charge, but at a lower rate, and may not get to the proper voltage.
With a built in regulator, you ae limited to replacing the alternator, unless you have the expertise to take the alternator apart (and properly reassemble same), and check and replace defective parts. this is providing you can get the needed parts.
At the same time, you'd also want to check the bearings for roughness or too much play. A properly remanufactured alternator has new bearings, brushes, voltage regulator (for built in types), and possibly diodes.
Wayne WA2YNE
WA2YNE is offline   Reply With Quote
