I'm also sorry for your loss. Before I bought my used Sorento I was aware of this problem through this forum. It was the first thing I checked after purchasing. Mine has the new style. The TSB is still there. I just looked it up and it even has a graphic of the new style vs. the old ribbed style. Below is the thread. You will probaly need a userid and password. Click on TSB...then scroll down until you see the TSB No. Good Luck... perhaps you can find a used engine yourself cheaper. I read somewhere in this forum that the Hyundia XG350L and some Sedona's may use the same engine. Then you could find a shop to install it. Below is the text from the TSB.
http://www.kiatechinfo.com/TechInfo/..._no=348&page=1
TSB No. KT2007073101 TSB Type General
Language English Published 8/3/2007
Model Sorento [BL](2003) Sorento [BL](2004) Sorento [BL](2005) Area N. America
Gr./Sys./Comp Engine Mechanical System / Cooling System / Coolant Reservoir Tank
DTC P0115 - Engine Coolant Temperature Circuit
P0116 - Engine Coolant Temperature Circuit Range/Performance
P0117 - Engine Coolant Temperature Circuit Low Input
P0118 - Engine Coolant Temperature Circuit High Input
P0119 - Engine Coolant Temperature Circuit Intermittent
Symptom EN9000 - MIL ON (Malfunction Indicator Lamp)
HAN003 - Others
Subject Sorento (BL) Coolant reservoir Replacement (Engine - 034)
Description This bulletin provides information related to Sorento models produced from 6/30/2002~10/3/2004. Some Sorento vehicles may overheat due to small cracks found on the bottom of the coolant reservoir due to repetitive temperature and pressure fluctuations. The new improved coolant tank allows some expansion and contraction found in many pressurized cooling systems.
This bulletin describes the proper service procedure for identifying and replacing the coolant reservoir tank.
Part Name
Part Number
25430 3E200QQK
Previous Design - Ribbed
New Design - Reinforced
Effective Vehicle Information 2003~2005 Sorento vehicles produced from June 30, 2002 ~ October 3, 2004.
Parts Information Part Name
Previous Part Number
New Part Number
25430 3E200
25430 3E200QQK
Service Procedure Repair procedure:
1. Raise hood and locate the coolant reservoir, cover the cap with a cotton shop towel and slowly remove the reservoir tank cap.
2. Use suction pump to remove the coolant or install a rubber plug or equivalent to prevent the coolant from leaking completely out of coolant reservoir tank when the hoses are removed.
a) Remove two hose clamps and hoses from the coolant reservoir tank.
b) Transfer overflow hose from old to new tank.
3. Remove three (3) retaining nuts holding the coolant reservoir tank.
a) Drain the remaining coolant into transfer container
b) Install new replacement tank to the vehicle, tighten retaining nuts to 84~108 inch lbs. (9.4~12.2 Nm)
c) Connect the rubber hoses and clamps as removed.
d) Fill the coolant reservoir to the correct level, install pressure cap. Coolant should be a 50/50 mixture unless otherwise specified on container.
WARRANTY CLAIM INFORMATION:
Claim Type
Causal P/N
Qty.
N Code
C Code
Repair Description
Labor Op Code
Time
Related Parts
Qty.
W
25430 3E200
0
N09
C07
Coolant Reservior Tank Replacement
25431F00
0.2
25430 3E200QQK
1
* Use sublet code of S7 for reimbursement of $2.25 per vehicle; this will provide a coolant allowance for 1 pint of concentrate Kia Engine Coolant mixed at 50/50. This will equal 1 qt. total of engine coolant; only fill with new coolant if necessary.
Prev Sedona (VQ) PCM Reprogram (DTC P0441/P0128) (Engine - 025) (UPDATED 2007-08-16)
Next Sorento Compressor Disc & Hub Replacement (Climate Control - 011)
