Old 01-30-2008, 01:57 AM   #1 (permalink)
pistnbroke
pistnbroke's Avatar
Drives: 2006 3.5 Sorento 4x4
Default crank bolt recall and TPS upgrade for improved mpg Australian KIA
Just been on the phone to kia and discovered that they are changing all crank bolts up to 2005 in Australia AND they have a update No 060057 to change the throttle position sensor to a version which gives quote " better fuel economy" ....now I dont know how this goes in the USA as this is Australian KIA originated information ...I was missed out because my vehicle is an ex demonstrator ...They also want full details of my bad first service to give the dealer a bollocking ....will keep you informed
Old 01-30-2008, 08:26 AM   #2 (permalink)
bajapatti
That's great!! Hope the recall is given in USA!!! Do keep us posted!!! The mechanic I took my car to for an unrelated issue said he's heard about the bolt problems, but has not serviced any in Minnesota. Hmmmmmmmmmm
bajapatti is offline   Reply With Quote
Old 01-30-2008, 11:42 AM   #3 (permalink)
cbotd
cbotd's Avatar
Drives: 02 Kawasiki 500R, 03 KIA Sorento EX, 04 Mazda 6s, 07 KIA Sedona EX
From KIA TECH, TSB dated 4/4/07
This bulletin provides information related to the Throttle Position Sensor (TPS) for Sorento & Sedona models. Some Sorento & Sedona vehicles may exhibit diagnostic trouble codes P0121, P0122 and/or P1121, P0700. This condition mainly occurs in high ambient or desert areas, and can be related to the occasional increase in contact resistance due to excessive wear of the inner elements of the TP sensor. This bulletin describes the proper service and adjustment procedure for replacing the TP Sensor.
cbotd is offline   Reply With Quote
Old 01-30-2008, 09:42 PM   #4 (permalink)
bajapatti
Thought you'd like to know that Kia contacted me today concerning the email I sent them about my concern for the crankshaft bolt. They told me that they weren't aware of any problems with it on the 2005 model. He said that they had recalls on the 2003 & 2004 models and it was redesigned for the 2005 on up models. Interesting.....
Old 01-31-2008, 08:38 AM   #5 (permalink)
Rossvickicampbell
Great - just got mine out of the workshop after 2 weeks for the driveline thump which they thought might have been caused by the TPS - which was replaced at the same time. Now you say it has to go back for the crank bolt recall.
cheers
Rossco
Rossvickicampbell is offline   Reply With Quote
Old 01-31-2008, 08:41 AM   #6 (permalink)
Rossvickicampbell
by the way - the TPS recall is a few months old now!
Rossco
Old 01-31-2008, 04:52 PM   #7 (permalink)
pistnbroke
pistnbroke's Avatar
read my lips " I MISSED OUT BECAUSE MY CAR WAS AN EX DEMONSTRATOR"
Old 01-31-2008, 09:35 PM   #8 (permalink)
Rossvickicampbell
so Pistn - why is the fact it is a demonstrator make a difference - if it is a recall and it is affected then it needs changing - dont understand your comment? Also just got off the phone to my Kia dealer - thre is a crank bolt recall as you said but it doesn't affect all Sorento years and models - my 04 EX is not one of the affected ones. Apparently this recall has been out for a while also.
Thanks for the heads up though - I wouldn't of known if you hadn't of mentioned it.
cheers
Old 01-31-2008, 10:01 PM   #9 (permalink)
cbotd
cbotd's Avatar
The link to this information can be found at:
http://www.kiatechinfo.com/
Registar for free and click on the TSB area. This link has photos and other helpful graphic displays and graphs. Here are the details though.
KT2007040401 4/4/2007 N. America
Effective for 3.5l Engines only
Part Name: Throttle Position Sensor
Previous Part No.: 35102 39000
New Part No.: 35102 39000FFF
Replacement Procedure:
1. Turn ignition OFF. Remove engine cover and disconnect electrical connector from TP Sensor.
2. Remove two (2) retaining screws from TP Sensor and remove from throttle body.
3. Install new TP Sensor to throttle body. Install retaining screws and hand tighten lightly. Adjustment will be required. Re-install electrical connector to TP Sensor.
4. Install Global Diagnostic System.
a. Select "System Option"
b. Select "Idle RPM Adjust Mode"
c. Apply Parking Brake
5. Select Neutral position and place engine in idle condition with A/C OFF.
6. Remove rubber plug and adjust using instructions provided on screen.
Adjust TPS:
7. Using the GDS scan tool, monitor current data using two (2) parameters:
• Closed Throttle Position Switch
• Throttle Position Voltage Value
8. Open throttle by hand very slowly until idle switch status switches to OFF. Note the TPS voltage value.
Set Base idle between 800~900 rpm
Adjust TPS:
Voltage:____________________________
9. Close throttle and record the TPS voltage.
Closed throttle voltage should be 30~65mV less than the voltage noted in step eight (8).
Adjust TP Sensor and repeat test as required.
10. Tighten TP Sensor screws as required. Torque is 12~18 inch lbs. Verify switching of throttle switch with throttle plate movement.
11. Install engine cover.
12. Clear any stored DTC which may have set during service procedure. Remove GDS tool from vehicle.
Old 01-31-2008, 10:29 PM   #10 (permalink)
04SorentoLX
Drives: 04 Sorento LX
cheers
TSB 7/23/2007
KT2007070901
Pre 2005 Sorento RWD 3.5L V6
Built 6/30/2002-1/28/2004
Old Part # (No number for package) one GOLD bolt and one BLACK washer
New Part # 23127 39801QQK one GREY bolt and one GREY washer package
Mine a 2004 LX was built 4/04 and has a grey bolt and washer already. Hense like maybe yours as well, it is not affected.
BTW pston in the down under do they hose you that bad for buying the demo's? wow!
