Originally Posted by JEREMY/NICOLE
Can you direct me to some detailed description of how to do this? It seems like something I'd be interested in trying. Thanks!
Not knowing where the diode was when I initially had this problem I found that there is another diode in the Overhead Courtesy Light. I checked it and it was good but replaced it anyway to no avail. I checked the switches out and traced out the lamp assembly and seemed to have the correct voltages which even faded out when the door was closed. It left me with scratching my head until I found this forum and the location of the diode in question. I opened the kick panel and found the diode which the dealer had already replaced under warranty. I pulled out the diode, checked it and found it was good. I put it back in the holder and it started to work. It looks like the diode holder may be the problem. If the contact become resistive the diode could draw more than the rated current causing the diode to fail.
I would be a little leary of permanently jumping the diode. One use of diodes besides rectification and switching is to prevent the reverse flow of voltage. If the diode in the lamp assembly is actually the switching diode used to remotely control the lamp and if that diode shorts, it could cause the voltage to go where it's not supposed to. If that happens, lots of other things could go poof.
Just a thought!!!
Cary
